Tractor Talk Discussion Forum
questions on small farmall
johns 960
04-13-2007 18:50:36
i was thinking about buying a new mower ( cub cadet modle gt 1554 )but started looking on this site and thought about maybe getting a small farmall c or b with a belly mower instead .would like to know a little about these tractors and do they cut very good. i think the 50s modles looks really good --- thanks for any help John L
BLW
04-16-2007 07:58:26
 Re: questions on small farmall in reply to johns 960, 04-13-2007 18:50:36
we have am A and super A both exce. for what you want-- super A has the touch control Hyd. makes it a lot better but if you want a classic the A is great to-- where are you located-- I might be able to help- there are a few still around here (northeast)
THEkyroastnear
04-14-2007 07:23:05
an uncle of mine had a allisB with a woods belly mower i used on his place while he recovered from surgery did a good job as long as you stayed in first gear he did not have much trimmingalot of things he edged with river gravel about 2ft. out. they dont trim well and many have independant hand brakes so you cant get too tight
glennster
04-14-2007 05:44:55
john, depends on what kind of ground your gonna mow. between my two farms, i cut around 8 acres of grass, all kind of terrain, flat areas, ditches, tree infested areas, shrubs, bushes and the atv trails thru the woods for the kids. my fleet includes a farmall b with a 59 woods belly, farmall cub, 59 woods belly with a swisher 60" tow behind off set, farmall m with a woods rm600 3pt finish mower, cub cadet 122 with a 42"deck, deere l10 automatic with a 42"deck, and a huster 295 zero turn with a 72"deck. flat ground with a few trees, the zero turn is the fastest. the litle deer has knobby tires on the back, use it for the ditches that arent too steep. the cub with trailer i use for real steep ditches, i have a homemade swingin drawbar i can run the swisher offset about 8 ft off the side of the tractor so the cub stays on level ground, the swisher runs in the steep ditches.(i hate to roll a machine over). the cub and b cut nice, but the pto is not live, so if you back up a lot, its a pain, but in open ground the cub and swisher take 10 feet of grass each pass.
pathahnd
04-14-2007 05:22:08
I've been mowing over 2 acres with my 1948 cub w/woods 59 and it does a nice job as long as you dont let it get long.I bought the tractor and mower 10 year ago for under a $1000. I did buy a Allis B w/woods 72" mower 2 year ago for $2200 I like it a lot betterfor time and power if i dont get around to mowing when i should. Both tractors are not made for tight spaces,threr time consuming backing up.the cub is better on steep ditch banks but I'm a little more nuts then most about how steep.
Blackhole49
04-14-2007 05:21:46
As others said, depends on what you are cutting. I used to cut 3 acres of reg. lawn with an 8n and a rear finish mower (14 yrs.). I sold the n went to a Kubota F-2000 5 yrs. ago and now I wonder why I waited so long. Now I mow a 1 mile trail in the neighbors field every week and it is too rough for the Kubota. I bough another 8n and finish mower. I would never have anything but a hydrostatic and diesel for the lawn, way easier and cheaper to operate.
fixerupper
04-13-2007 20:53:28
Sometimes these little tractors that have been used for mowing get a bad rap because they have been neglected and abused. Anything will fall apart if it's not taken care of. They aren't used in the field so people don't think they have to be serviced as well as one that is used for 'real' work. My dad bought a Farmall B in the winter of 1974, put a woods 5ft belly mower on it and started mowing. In the winter of 75 I did a major overhaul on it and since then all that's been done to it is a new starter and gennie. That's it! It's kind of hard to estimate the amount of hours he's put on it since then, but 4000 would be a good guess, so the dependability has been really good. On the downside, it is not the best in tight spots where you have to stop and back up, because you have to wait for the mower to stop before you can shift gears. It can turn on a dime in a relatively small area, but the pivot wheel will chew the sod some, depending on what the tread is on the wheels. One good thing about a small tractor is it can also be used for more than mowing, like pulling your pickup out of the mud or something like that. How well they cut depends on what kind of mower is under it. I've only worked around a woods 59, which is more of a finishing mower.I don't know much about any of the other brands out there. Jim
dds-inc
04-13-2007 20:28:11
i'll tell you what, you can't beat the speed and smooth cut of a zero turn, but i can buy two A's for the price of a zero.
old
04-13-2007 19:41:23
A lot depends on how big an area you have and how good you want it. If you want a golf course green no the cub /A/B is not the way to go but if you have say 5-10 arces then ya it will be ok but also a ford 8N and brush hog will do well
dave guest
04-13-2007 19:25:28
Got a cub. Got an A. Love them little red things. But you gotta love em or you won't keep em. Had em 20 years and lotta work. They do everything I want but nice and slow. Perfect when you are 63 years old. 2 blades, 2 belly mowers, what more do you need always a spare. 2 acres for me and sometimes 6 for some body else.
John M
04-13-2007 19:13:53
Im going to honest with you, I thought a Cub or 154 would work good for me so I bought a 154 with a 60" deck. After the first time I was regreting doing it. My old Craftsman was faster than the 154 and it took LESS time to cut it with the Craftsman. I borowed a neighbors Super A with a 6 ft deck and found it to big for my back yard, worked good in the front and another section of my yard, and for roadside mowing and getting under the limbs in my feild it was fine.I still use the 154 for that, but I bought a Cub cadet Commercial M50 Tank Zero Turn Mower. I have cut my time from 4 hours start to finish to 2 hours including trimming with the Weedeater.I looked at alot of Zer Turns and went with the Cub cadet since I have 5 dealers withing a 20 mile radius, and in a pinch, the Home Depot has SOME of the things I may need when the dealer isnt open.Just my opinion and my barn is full of Farmalls.
Lumpy
04-13-2007 19:12:25
At one time I had the same idea. Found me a 1947 Farmall B in fairly good shape ..... I thought, paid $700.00 for it. Sheet metal was all there and in good shape. Rear tires were good, front fair. I started cleaning it up to give it new paint. Found a cracked engine block, had it fixed. So I went further, by the time I was ready for a mower I had just over $1300.00 into it. Time to find a mower... new was my only option, at the price of $1578.00, that was mower only! No installation. Now I would have had just under $3000.00 into it and all I could do with it is mow grass with it. Also it is alot bigger and heavier than, lets say your average 20 hp LGT... plus the LGT is more versatile and easier to manuever. Just my .02!
