Tractor Talk Discussion Forum
400 farmall power steering
chris cherney
04-14-2007 09:53:26
bought a 400 and am missing something on the power stering, it has the pump on the shaft and one hose going to the resovore and out of the bottom of the res. it has a hose 8" long that is not hooked up, and i can not figure out where it should go.
georgeky
04-14-2007 10:38:27
 Re: 400 farmall power steering in reply to chris cherney, 04-14-2007 09:53:26
Chris it hooks to the left valve straight above the other line. The fitting hooks to the bottom of that valve. This is one of the remote valves it must have the power steering flow control valve in it.
old
04-14-2007 10:14:31
If your talking about the part on the steering shaft thats not a pump but a hyd motor. I just looked in my manaul-I-T IH-10 and sorry it doesn't show enough info for me to help. If the weather was better I might be able to help you trace them down since I have to work on a 450 soon but that might be a week or 2 away so if you still need the info then I could look for you
