Tractor Talk Discussion Forum
Transmission--Clutch?
Jiles
04-16-2007 19:39:03
I have a 364 I.H. When I am using the tractor for heavy work, it is very difficult to change gears. I have to use an extreme amount of pressure to get from forward low, or second, to reverse. If I put the Hi-Low leaver into nutral, it slips out easily. The gears will grind just a little when I put it back into gear. The clutch disengages easily and the adjustment is correct. Any suggestions?
