Tractor Talk Discussion Forum
Lye Gravy - Can't find any lye
Justin-PA
04-17-2007 09:29:44
Hi...I want to use Lye gravy to clean the grease and paint off my 1956 massey baler (resoration project). I"ve used electrolysis with good results on the smaller parts, but I don"t have a tank big enough to dip the whole baler frame in (man that would be nice!)
I have 2 problems though, first off FIT"s website is currently down so I can"t find the recipe. Can anyone send it to me?
2nd, I can"t find any lye in the stores. Closest thing I"ve found is Drano Crystal Clog Remover, which is about 60% Sodium Hydroxide (lye). Will this work?
Any help appreciated...thanks!
Justin
msb
04-17-2007 18:02:42
 Re: Lye Gravy - Can't find any lye in reply to Justin-PA, 04-17-2007 09:29:44
Lowes carry lye. Used to be 10 cents a can when I was a kid.Its now about $4.95. Some good clean wood ashes is essentially the same as lye and a LOT cheaper.
stn.tn.
04-17-2007 17:42:00
I myself use avaition stripper, can be purchased at about any discount auto parts store(example, auto zone ,advance auto,etc..,)WORKS SUPER QUICK,works great. apply w/paint brush or etc. not that expensive either.
Unimog
04-17-2007 14:27:49
I picked up some Red Devil lye in Home depot in
the plumbing dept.
gcs
04-17-2007 13:48:15
I saw some lye in WalMart last week, bottom shelf in the chemical/cleaners aisle
hay
04-17-2007 12:25:31
try E-Z OFF oven cleaner. just spray on and wait and hose it off. works almost as good as lye and much safer and cheaper and easier to use.
IH2444
04-17-2007 14:44:52
 Re: Lye Gravy - Can't find any lye in reply to hay, 04-17-2007 12:25:31
Yep that stuff works great. Also found some grill cleaner that will eat any paint except epoxy paint off.
Stan(PA)
04-17-2007 11:22:15
I"ve always found it at the Hardware store, not supermakets.
Justin-PA
04-17-2007 12:39:22
 Re: Lye Gravy - Can't find any lye in reply to Stan(PA), 04-17-2007 11:22:15
I'll check a few more hardware stores tonight...thanks for the suggestion.
Ken Macfarlane
04-17-2007 10:06:12
You can probably blame the meth heads for some of the problem finding it, they use it for cooking their drugs I think. Biodiesel guys use it to I think to neutralize the acids in their fuel?
bjb in Ne
04-17-2007 09:57:39
As far as drano goes for using it as a lye source, it would depend on what that other 40% make up is. Post the rest of the components and I might be able to tell what they are/ would do if used.
Justin-PA
04-17-2007 12:37:09
 Re: Lye Gravy - Can't find any lye in reply to bjb in Ne, 04-17-2007 09:57:39
This is from an MSDS for the product, found on the web...
Chemical Percent Sodium hydroxide 30-60 Aluminum 1-5 Sodium nitrate 15-40 Sodium chloride 7-13
jdhbag
04-17-2007 09:42:29
Boyer Corp. will sell you a case of Red Crown lye for around $55.00 includeing shipping. 1 (800) 323-3040. Still cheaper than commercial sand blasting then u can make soap with the rest.
