Tractor Talk Discussion Forum
td-6 trouble
Jacob S
04-19-2007 05:01:55
I have a international td-6 dozer. it starts on gas then goes to diesel. but it will not run on diesel.it did run fine before I changed the fuel filters and now it is not geting fuel to the pump. what do I do.
old
04-19-2007 07:59:40
 Re: td-6 trouble in reply to Jacob S, 04-19-2007 05:01:55
You say you changed the filters did you open up the bleed screws to make sure you had all the air out of the filters?? If you need info on how to do that etc. Drop me an e-mail I still have an OPs manaul for the TD6 so I can scan pages from it for you
Bill46
04-19-2007 05:16:13
Sounds like you still got air in her Jacob. Fill the diesel tank up. Make sure the fuel is turned on and open the bleed screws on the filters. Leave them open until you start getting fuel out of them. Fuel now, not bubbles.
Crack the injector lines at the injectors. Start in on gas and move the throttle just a notch or 2. When you start to get fuel from the lines...tighten half of them. Keep it running for a few seconds and tighten the rest of the lines. It should start to smoke pretty heavy. When it does...throw the compression release and pull the throttle down a couple more notches till she runs smooth.
Might take a couple of fill ups on gas so be careful and don't try and put gas in her while she's running or hot. It won't run long on that little tank.
She's just got to burp the air out...and she will be fine.
