Tractor Talk Discussion Forum
wut is the purpose of plowing stupid question
jlmtractor
04-19-2007 12:19:47
why do you plow i am not much of a farmer i have a little garden and i just till it but why do you plow a field i never could get anything but a laugh from the local farmers sorry if this is a stupid question
jlmtractor
04-20-2007 13:55:58
 Re: wut is the purpose of plowing stupid question in reply to jlmtractor , 04-19-2007 12:19:47
thanks i have just always wondered i had a general idea just didnt no if it was right
MLD
04-20-2007 05:28:25
It gives you fresh soil to plant in & buries the old waste material in the ground where it can rot & reblenish the soil. Besides, could you ever picture a tractor with 20' rotary tiller working up a couple hunderd acres???
Dave 2N
04-20-2007 04:01:59
Because it's fun!
Allan In NE
04-20-2007 02:49:07
Short Version:
It is "healthy" for the soil.
Allan
richard in nz
04-19-2007 23:10:01
From my old college notes: A properley adjusted plough will simultaneousley achieve these several functions in one pass through the soil: 1 It will completely bury weeds, and in so doing, will cut through any deep roots. 2 It will leve the soil in a suitable condition for producing a seed bed with a minimum amount of further cultivation. 3 It will incorperate crop residues, farmyard manure and other organic matter into the soil to improve its texture and fertility. 4 It will restore soil struture when damage has resulted from the passage of heavy eqipment. 5 It will aerate and expose the soil to the elements so its texture is improved by weathering and thereby reduce the work requred to produce a good seed bed. Things were long winded back then!
VADAVE
04-19-2007 16:08:06
Boy you really want to stir up a debate.
There are two different schools of thought on plowing. You've one side and in general that is a pretty good position. The other side says there is no reason to plow and there is evidence that ground that has been in continuous no-till shows no decline in yields and better soil structure, plus it costs less in that there are less passes over the field and therefore less wear on the equipment and less fuel burned. The continious no-till group had footing until the arrival of the no-till drill. Prior to that the ground had to be worked up for a drill to work correctly.
My opinion--and that is what it is. The no-till boys are right in that it does cost less time and money to get the seed in the ground. I am trying it right now and so far my experience is that continious no-till is not necessary to see equal yields to tilled ground. My yields match! Year ago I till 1/2 of a field and no-tilled the other 1/2, otherwise treated the field the same--could tell the difference at harvest.
What I will say is that it doesn't matter, either tilled or no-tilled the fields need to be deep-tilled or ripped every so often to remove compaction. One more thing no-till drills and deep-till equipment are expensive particularly since they are relatively new.
Joe (Wa)
04-19-2007 15:41:49
Some of the benefit of plowing is to aerate the soil providing oxygen to accelerate decomposing of organic matter. Same as turning & stirring compost.
Joe
135 Fan
04-19-2007 15:49:48
 Re: wut is the purpose of plowing stupid question in reply to Joe (Wa), 04-19-2007 15:41:49
Even if you use a rototiller, they recommend deep cultivating or plowing every 5 years as the soil that doesn't get tilled gets too hard packed. Dave
jdemaris
04-19-2007 12:41:20
There are many agricultural "experts" that argue that plowing is not necessary and damages soil structure - and causes errosion. I'm not an expert though. I see it like this. You start out with a field full of some sort of residue on top - old crops, dead grass, manure, etc. And, the ground is often hard. You plow it - and it gets rolled over - although the results can vary from moldboard to chisel plows. The organic stuff on top gets sent down a little deeper where new crops can better use it. After plowing, and it dries a little, you can disk it to make the soil fine engough to allow seeds to be planted and later sprout.
An option that used to be popular in my area of hard-pan soil New York - was no-till seeding. The County Ag. department was pushing it for awhile in attempts to stop plowing and limit errosion. Doing so takes a special "no-till" seeder for most crops and also takes a lot of chemcials. Some "experts" finally decided it was not cost effective - and perhaps did more damage with all the chemicals needed. Most experiments with no-till in my area was with corn and the results were not very good. Somebody else might give you different reasons for plowing, or perhaps for not plowing.
Brokenwrench
04-19-2007 12:34:49
I`m sure others will have a better answer but I`ll give it a shot. When you plow you actually turn the topside (sod, trash, stuble, etc) under.
That actually serves as compost.
RustyFarmall
04-19-2007 12:33:58
Because we don't have time to run a garden tiller across a few hundred acres.
shannon from ohio
04-20-2007 16:04:16
 Re: wut is the purpose of plowing stupid question in reply to RustyFarmall, 04-19-2007 12:33:58
Garden tiller? How about one of them 2 cycle ones with about a 10 inch path on 200 or 300 acres LOL....
jd2120
04-19-2007 12:30:56
well for different reasons, it'll differ from person to person, but i like to plow because at the end of the season you usually have trash in the field to either burn off or you can plow it under, it will rot and go back in to the ground as humas. another reason is if its hard sticky clay, winter freezing and thawing will loosen up the ground and in the spring it'll be really soft and workable, not have big clods in it and have to deal with those all year.
KRUSS1
04-19-2007 13:31:37
 Re: wut is the purpose of plowing stupid question in reply to jd2120, 04-19-2007 12:30:56
A lot of people plow because that is how thet always did it. Anyone in an erosion prone soil has learned how to farm without a plow (or at least seen others learn).
JohnDeere2Cylinder
04-19-2007 19:28:01
 Re: wut is the purpose of plowing stupid question in reply to KRUSS1, 04-19-2007 13:31:37
It turns the worms upside down. They like that.
steveormary
04-20-2007 06:41:28
 Re: wut is the purpose of plowing stupid question in reply to JohnDeere2Cylinder, 04-19-2007 19:28:01
Well now, You have the smell of fresh earth"the smell of deisel smoke and the bark of the old 706 ger.making 5mph plowing with an IH simi-mount 4-16 plow.
steveormary
