Tractor Talk Discussion Forum
john deere glass fuel filters
francis pawelek
04-19-2007 13:49:45
has anyone ever found a way to reclean these?is it even possible?seems like there could be a way to go thru top inlet holes and blow thru the top and clean them to be able to reuse them again,thanks
jdemaris
04-20-2007 05:57:31
 Re: john deere glass fuel filters in reply to francis pawelek, 04-19-2007 13:49:45
When Deere first came out with the new rectangle Standyne filters - we found out they'd plug real easy with ice. That's not a dirt problem - it an issue where water collects at the bottom, freezes solid, and the machine quits. The old round filters did not plug like that unless they had a LOT of water. The new filters only needed a little to freeze. We had a fleet of rental Deere crawlers, backhoes, etc. So - often in the winter - we DID remove filters, thaw them out, drain them, and re-install. It would of been ridiculous to change with new every time. But again - that's water - not dirt.
Steven@AZ
04-19-2007 17:42:45
Good way to cause a ruckus!
In ANY diesel engine the fuel filters are the cheapest maintenance item that you can replace! Before trying to be cheap on fuel system parts, check out the prices on injector and pump rebuilds...
msb
04-19-2007 17:33:05
Toss them in the trash can. They are a lot cheaper than an injection pump rebuild for a sticking metering valve.We are talking microns of filtration here.And that would be equivelent in size to a pimple on a gnat's a$$ or maybe a little smaller.
mjbrown
04-19-2007 15:38:51
I think they are about ten bucks for a spanking new one!
Big Mike. LOL!
04-19-2007 15:38:33
Bud, you could pinch a penny, and make ol' Abe HOLLAR!!! ":^D Replace them!!!
Donnie Baker
04-19-2007 15:31:05
Makes almost as much sense as rinsing out oil filters and reusing them, get real dude there are other places to try to save money and this is not one of them. I gotta go
Rob in Indiana
04-19-2007 14:38:29
your kidding right?
Tx Jim
04-19-2007 14:34:14
Are you refering to the rectangle fuel filters? If so why would not just buy new filters? Tx Jim
francis pawelek
04-19-2007 16:12:16
 Re: john deere glass fuel filters in reply to Tx Jim, 04-19-2007 14:34:14
well i got the answer i was looking for,kinda like them surveys the have that are ridiculous too,of course nobody can clean out the jd filters,once they are slowing down your machine,its a guaranteed fix to shitcan the filters and get new ones cause the lower parts are already sucked inward and unable to be saved,i got everyones attention on that one,of course when i just spent 9600.00 dollars plus restoring a john deere 7020,thats the last thing i'm worried about buying,this was a cool survey without having to start a survey,great going guys,have a nice afternoon
