Tractor Talk Discussion Forum
New job for that 1066
IaGary
04-19-2007 17:47:06
third party image
Put the loader on it today.
Now we'll test out that tractor.
georgeky
04-20-2007 08:55:41
 Re: New job for that 1066 in reply to IaGary, 04-19-2007 17:47:06
Gary how do like that Allied loader. I bought two of them because of the thickness of the metel they were built out of. One I got in 96 and the other last year. They are good loaders. Plus I got a really good deal on both. A friend of mine is a dealor and let me have them at his cost. I did have to drive to Louisville to pick up the first one and to Clarksville Indiana for the latter one, they moved the warehouse across the river.
Allan In NE
04-20-2007 02:21:04
Darnit Gary,
You make it look so darned easy. Sometimes, I think I'm my own worst enemy. :>)
That outfit sure ought to do the trick.
Allan
IaGary
04-20-2007 03:58:34
 Re: New job for that 1066 in reply to Allan In NE, 04-20-2007 02:21:04
Hey Allan remember that loose steering?
The bottom trunion(sp) on the steer cylinder was gone.(:~})
Put a new set in it yesterday.
Allan In NE
04-20-2007 04:04:07
 Re: New job for that 1066 in reply to IaGary, 04-20-2007 03:58:34
How do the hydraulics work under that loader?
I had no way of testing, but they sure seemed responsive enough.
Sorry 'bout the trunion. I should have spotted that bad boy.
Allan
IaGary
04-20-2007 04:09:34
 Re: New job for that 1066 in reply to Allan In NE, 04-20-2007 04:04:07
Wasn't your job to fix the steering.
The hydraulics seem strong so far. We will find out on hay tomorrow.
Lifts the loader right up when empty at low idle.
Gary
Allan In NE
04-20-2007 04:15:22
 Re: New job for that 1066 in reply to IaGary, 04-20-2007 04:09:34
I was really quite concerned when I swapped my loader over on to the little Hydro 70. Was scared to death that it was going to end up being one of those "slow" response things.
Was pleasantly surprised when it operates every bit as fast as the 1066. Guess, come to think of it, they use the same silly pump tho. :>)
Allan
Ed1
04-20-2007 05:43:42
 Re: New job for that 1066 in reply to Allan In NE, 04-20-2007 04:15:22
Yes the 06,56,66,86,88 (including the hydro 70 & 100 and 544)through to the Case/IH series all came with really good hydraulic systems. My dad's 504 even had a really good hydraulic system. 12,17 and 23gpm come to mind for the 56-86's. They also had some of the highest 3point lift specs better than Deere, Ford, etc. One farmer purchased a 3pt hitch planter with fertlizer hoppers and his big John Deer couldn't lift it. Tried it on a IH and it picked it right up. His green fram started turning red.
Be careful though I changes a metal hose out for a smaller diamater rubber hose on my 686 and the speed decreased with a ever so slight delay. Need to replace it with a bigger diamater hose of a greater pressure rating. Possibly return to pipe for most of the run from the diverter valve to the spools by the seat.
Allan In NE
04-20-2007 06:20:36
 Re: New job for that 1066 in reply to Ed1, 04-20-2007 05:43:42
For sure,
I don't think a guy can get away with anything less than 1/2" lines on these older tractors.
The newer rigs run at a heck of a lot higher pressure so they all seem to use the 3/8" stuff.
Allan
David in Wales
04-20-2007 00:35:52
Mornin Gary;
How come you dont have a ROPS on that tractor? Ar'nt they compulsary in the US?
Cheers David
IaGary
04-20-2007 04:03:08
 Re: New job for that 1066 in reply to David in Wales, 04-20-2007 00:35:52
ROPS are mandatory on the new ones but not the ones sold before the law took affect.
I may put one on this 1066 however.
Bad part is getting into low buildings where I want to store hay.
Gary
Allan In NE
04-20-2007 04:06:24
 Re: New job for that 1066 in reply to IaGary, 04-20-2007 04:03:08
Hey Gary,
Maybe Dave will sell you that one off the little Massey that he just bought. The freight across the pond might be a stinker tho. :>)
Allan
grazer
04-19-2007 20:11:17
I thought you would be busy in field by now Gary.
IaGary
04-20-2007 04:18:51
 Re: New job for that 1066 in reply to grazer, 04-19-2007 20:11:17
Yes and No.
To cold and wet to plant but been doing a little tillage work so when it warms I can just plant.
Thats why I switched the loader to the 1066 so I can use the 1086 on the sprayer.
I finished planting oats yesterday.
Everyone plants to few of oats to own there own drill so I custom drilled oats for 4 differant guys. But only totaled 100 acres all together.
Next week on the corn. Maybe???
Gary
Janicholson
04-19-2007 18:40:33
Very slick, For a moment I thought it had a cab, then I realized it was behind EEEKKK. JimN
