Tractor Talk Discussion Forum
One-Wire Alternator to 3-Wire
Gene-AL
04-19-2007 19:57:27
I've read many posts about one-wire and 3-wire alternator setups, but it was never completely clear whether or not a 'one-wire' alternator could function the same as a 3-wire if an 'Idiot light' ignition-switched circuit was added. I tried it and it did work - at least with this one alternator.
Original tractor charging system was an alternaor or generator, with an external regulator, but that had been replaced with a GM style alternator sold as a 'one-wire' unit, which required the engine to be reved up to start the charging process.
Removing the original tractor voltage regulator plug from regulator and terminating the switched 'Idiot light' wire at the #1 terminal on the 'one-wire' unit worked correctly. Charge-light goes out immediately after engine is started. Charging proved by battery voltage slowly rising above 13V and screwdriver test for magnetism at end-center of alternator housing. Results may vary with some 'one-wire' units - don't know the answer to that.
John T
04-20-2007 10:00:22
 Re: One-Wire Alternator to 3-Wire in reply to Gene-AL, 04-19-2007 19:57:27
Gene, I usually use a 10 ohm current limiting protection resistor to excite those 3 wire alternators (on the lil No 1 terminal) but an "idiot light" serves the same purpose allowing sufficient excitation current and voltage to get her to start charging. HOWEVER use incandescent cuz if its like an LED it may be of to high resistance and not provide sufficient current. Some One Wires require a higher RPM to excite and some draw a small trickle discharge, I like the GM 10 SI 3 wires converted as above to function similar to a one wire.
John T
Gene-AL
04-20-2007 12:02:53
 Re: One-Wire Alternator to 3-Wire in reply to John T, 04-20-2007 10:00:22
John T., The tractor was already equipped with a 12V charge indicator lamp which, fortunately, was of a suitable size and also wired to the old alt/gen connector plug via one terminal on the old VR plug. After checking the manufacturer's electrical diagram, it took only a few minutes to unplug the original voltage regulator and then add a 6" wire extension with a terminal lug at the alternator end to make the change over(JD-2120).
Gene-AL
04-20-2007 08:18:55
Yes, the charge-indicator light went out immediately when the diesel engine started, indicating that the alternator was being excited - no more reving up and then hoping it was charging as before (no Ammeter on this tractor). It is probably a remanufactured 37-Amp 'one wire' alternator.
Jon, thanks for the clearing that up.
Jon Hagen
04-20-2007 06:06:13
I build both one wire and three wire Delco alternators for what ever best fits the application. The brand of one wire regulators I buy have instructions with them that they can be used with an alt warning light by connecting it to the #1 regulator terminal. Atleast with this brand, you do not need to add the #2 sense wire, although I have installed it and they work fine either way. The box of regulators came with instructions saying that there is no problem using these regulators in any application where a charge light or lower excite rpm is desired.
One trap not to fall into is buying more "one wire" alternator than you need, the smaller the amp output, the lower the excite rpm. A 37 amp "0ne wire" Delco will excite at about 1/2 the rpm of a 72 amp "one wire" unit.
By the way, there have always been FACTORY "one wire" Delco alternators. The "one wire" version of the Delco 27SI have been used in truck industrial and marine applications since the 70's.
The factory Delco"one wire" regulator parts fit right into the smaller 10SI-12SI alternators, although I rarely use them. They cost 8 times as much as an aftermarket "one wire" regulator. They have an externally adjustible voltage adjustment which I feel has little value for the average user.
cj3b_jeep
04-20-2007 04:57:53
A one-wire alternator canot be used with an idiot light, only an ammeter or volt meter, my old Jeep is set up with a one-wire, which has to self excite just above idle, right around 700 rpms. It used to kick in at about 1,000 rpms, but I took it to a generator shop and they did something to it to make it kick in lower. The three wire version excites via the battery. Idiot lights are a strange thing, having power coming in one side from the battery via the key switch, and ground coming from the alternator, once the alternator is charging, it sends a second positive to the light, turning it off. All-in All, I think the three wire is a better setup, and also, if you have to replace one, it's much easier to find the three wire.
jpl
04-20-2007 02:23:52
sorry,i meant john t not bob, its early yet.
jpl
04-20-2007 02:01:35
yes, mine kicks in at past idle now, no more revving it up.
jpl
04-20-2007 01:56:49
I had a one wire on m, it quit charging, before you just revved it up and it charged, i had it hooked through the ammeter, (i hooked a small wire to # 1 terminal and then to ignition sw, then put a toggle switch in the wire betwwen switch and alt, i start tractor and hit the toggle switch and it excites the alt and it charges, must been bad self exciter, works fine now.) next time i;ll use a three wire and hook up as per bobs instructions in archives. now if i can figure how to mount a alt on 560 gasser i;ll put on a three wire this time.
midlam
04-19-2007 20:03:49
does alternator also kick on at a lower RPM with the light connected?
