Tractor Talk Discussion Forum
PHOTO - the plough at work
David in Wales
04-20-2007 00:07:31
third party image
Hi Gang;
You can now see the furrows are set up high rather than being turned flat. The chains pull the solid steel "boats" which together with the "diablo" wheels press the furrows into shape.
This particular plough has been heavily modified for competition work, and has a lot of removable weights to aid penetration.
Cheers David
1936
04-20-2007 16:05:05
 Re: PHOTO - the plough at work in reply to David in Wales, 04-20-2007 00:07:31
Interersting very interesting. When you can send a photo of the plow out of the ground. Straight no till for years has a yield reduction over a period of time.
Mike M
04-20-2007 10:37:08
Looks like cheating to me ??
I guess I just don't see the point ? As soon as you run the disk over it and get it ready to plant all that picture perfect is GONE !
Is the US the only ones who moved away from those soil erroding practices to no till ?
georgeky
04-20-2007 13:56:56
 Re: PHOTO - the plough at work in reply to Mike M, 04-20-2007 10:37:08
Mike there are still lots of folks in the US that plow ground. I am one of them, and have lots of neighbors that do also.
mjbrown
04-20-2007 12:16:53
The seed is broadcast on the furrows, falls into the valleys THEN the harrow goes over it knocking off the pointy tops into the valleys covering the seed. It's an old timey thing, no longer practiced.
02
04-20-2007 09:25:30
That's incredible.
charles hess
04-20-2007 08:15:03
Thats precession!!!Look forward to seeing more photos of whole plots an of start of contest(split-finshing furrows) Great folks are keeping contests going,
55 50
04-20-2007 07:24:53
What fun is plowing like that with everything "perfect"? Reminds me of cloning sheep and other things of that nature. I like to drop a "regular" plow in the ground and "let er rip"!
MF Poor
04-20-2007 03:46:38
Thanks David! I'm amazed at all the built-in adjustability of those plows. In a match, do they only use these in grassland ploughing?
