Tractor Talk Discussion Forum
question power unit looks like a b c farmall eng ?
roger roland
04-22-2007 14:21:50
i found a Ericson lift unit & the eng looks just like my farmall C eng i bought it from old guy & took the carb & manifold home to match up to mine lookd same anyway is there a # or something that will say what block it is ? only other thing i think ill take off it is the head but if its an super block ? id like to keep any ideas ?
Larry in Mo
04-22-2007 14:36:49
 Re: question power unit looks like a b c farmall e in reply to roger roland, 04-22-2007 14:21:50
Not much difference in the A or Super A, C etc. Larger sleeves and pistons, and an increase in rpm"s made the difference. Locate the sn plate, should be on the flywheel housing, probably left side. The model data on the top line should give you some idea. LE
RustyFarmall
04-22-2007 14:26:51
If it were me, I'd bring the whole thing home. Then you can pick and choose and sort the good from the bad. If any of it goes for scrap, you might as well reap the benefits instead of someone else.
