Tractor Talk Discussion Forum
Perfect guy day
PhilcaseinWPa
04-23-2007 08:11:54
Saturday was the perfect guy day for me.
Weather was excellent.. Tee shirt and AM coffee on the porch....
Got to drive truck a little in the morning....
Then I was finally able to get the plow out and work up some ground.....
Then I got to work on a tractor that wasn't running and got it to go....
Meat and potatoes for supper....
And a beer before bed!
third party image
third party image
third party image
And it got to 70+ degrees Also!!
So I got a little ground ready for some sweet corn. I'm leaving work early today and put it in.
Rain tonight.
Have a good one!
Phil
MLD
04-24-2007 09:27:43
 Re: Perfect guy day in reply to PhilcaseinWPa, 04-23-2007 08:11:54
You must not have the plow set right or your points are worn out? I've never had to adjust to make the front plow go in the ground & have the back one out?? Something has got to be wrong there. Adjusting the toplink should angle the plow & or point from front to back, not control the depth of the front plow. You may need to adjust your draftlink up or down?
Walt Davies
04-23-2007 08:34:43
Isn't that an awful big tractor for a single bottom plow or are you hiding another one back there.
I pull a 16 in 3 and 4 bottom with my Case LA.
Walt
PhilcaseinWPa
04-23-2007 12:42:24
 Re: Perfect guy day in reply to Walt Davies, 04-23-2007 08:34:43
I'm pulling 3 16s in that picture the angle of the shot hides it I guess. Actually that green plow and red tractor don't get along too well. When I adjust the top link so the front doesn't go too deep the last bottom barely lifts enough to clear the ground. I have a lot of scuff marks to prove that. Power wise I think I could be pulling 4 18s but I work with what I have for now. I would really like to have a 3X18 two way plow. That would work nice on my hills and small fields.
Phil
