Tractor Talk Discussion Forum
O/T 80 F350 ford front end questiopn
37 chieg
04-23-2007 14:32:11
On my 80 ford There are two struts that go from the axle about 2 ft back and have rubber bushings on the ends, and are secured by a large washer, and nut. If I want to replace the rubber bushings is this a big job? Might get my tractor hauler running before my weed mowing season after all.
Stan
Leland
04-24-2007 09:08:50
 Re: O/T 80 F350 ford front end questiopn in reply to 37 chieg, 04-23-2007 14:32:11
I have used a come along to pull them forward enough to replace bushings a lot easier
Wild Bill
04-23-2007 20:28:02
Loosen the spring mounts on each side under the hood (on top of the springs) just loosen them to give them enough slack to move a little, then take the nuts off of the backs of the radius arms. Laying down behind the axle, take your foot and give the axles a good kick foward, The radius arm should pop right out and let you put your bushing in.
frankiee
04-23-2007 16:28:06
Can be easy enough
Or
Can be a pain
especialy if the radius rod breaks. I have done this before.
37 chief
04-23-2007 16:49:06
 Re: O/T 80 F350 ford front end questiopn in reply to frankiee, 04-23-2007 16:28:06
I guess I need to know if the strut needs to come completely off, or can it be pulled forward enough to replace the bushings. I don't have a rust problem. Stan
Gary from Va
04-23-2007 17:45:19
 Re: O/T 80 F350 ford front end questiopn in reply to 37 chief, 04-23-2007 16:49:06
I've done them a few times, common repair on older twin I beam suspension. You can pull it forward, but you will fight it the whole way. And, you're working around a big chunk of steel onder tension. Kinda like a recipie for an ER visit. An easier way is to jack and block the frame up, remove the tire, put a jack under the spindle to relieve the spring tension, and grind the rivet heads off that hold the radius arm brackets to the frame. Use a punch and a big hammer to knock out the rivets. Then just remove the bracket and replace the bushings. Use grade 8 7/16" bolts, washers, and lock nuts to reattach the brackets. Or, drill out the holes and use 1/2" bolts for the extra piece of mind. I've done a few like this, and never had any problems.
JD9295
04-23-2007 16:15:22
Start soaking them down in Kroil now every day for about a week, then start on it
Jim K
04-23-2007 14:40:29
Not a bad job just a little time consuming, and
You'll want a 3/4" drive ratchet or a good impact wrench, and a strong buddy wouldn't hurt either.
