Tractor Talk Discussion Forum
identifying wd45
f bell
04-24-2007 18:06:12
Where do I check on my friends allis chalmers wd45 for the serial number or some identifying factor. Would like to know the value and what implements are compatible. Thanks alot for any info. Can't seem to find the history of the 45.
John (C-IL)
04-25-2007 04:42:28
 Re: identifying wd45 in reply to f bell, 04-24-2007 18:06:12
What old said, plus, the tractor serial number is on the flat verticle machined surface on the left axle between the brake spring hole and the adjusting bolt. WD numbers are WD0007 through WD146606, WD45 numbers are WD146607 through WD236???. The engine serial number is behind the air hose going from the air cleaner to the carb. WD's start with WD and WD45's start with 45, unless the tractor was the victim of an engine change.
John (C-IL)
04-25-2007 11:31:45
 Re: identifying wd45 in reply to John (C-IL), 04-25-2007 04:42:28
The ending number for the WD45 was WD236958 in 1957
old
04-24-2007 18:37:07
Well first off a WD and an WD45 look a lot alike so it can be either one and a good number of people will call a WD a WD45 and there 2 differant models. On both the serail number is on the left axle houseing. If you walk up behind it theres a flat spot just below the brake cover. Now a WD will have a stright shifter and a bolt on side plate on the engine on the right hand side. The WD45 has a curve to the shifter and no bolt on plate on the right side of the engine. The very late model WDs did have the curve shifter so some times that will not help. Check down in the Allis forum for a lot more info. I may self own both a WD and a WD45
