Tractor Talk Discussion Forum
David in Wales - late entry - plowing contest
RayP(MI)
04-25-2007 17:56:12
third party image
Just finished "plowing" my oat field. An old sod, many years old. Very rough job, I'm sure dead last on David's plowing contest. I worked hard to adjust plow for smoother job, to no avail. I'm sure not looking forward to disking it over a couple three times, before dragging. I plowed it on the diagonal to try to break up previous furrows and try to level it out. Years ago, my dad used to plow oppositely each year, so dead furrows became back furrows, etc. Land was rented several years, and those farmers weren't so careful! (Spent lot of time going around headlands this way!)
Lou
04-26-2007 08:09:49
 Re: David in Wales - late entry - plowing contest in reply to RayP(MI), 04-25-2007 17:56:12
I like the looks of it , looks more like the real world.
Gettin OLD
04-25-2007 19:15:33
DAVID,don't feel bad at all.seen fields lot worse than that,even some of my own some years.
RayP(MI)
04-25-2007 17:59:52
third party image
Picture of whole field - yes it is possible to plow up hill both ways! Worst yet, it was up hill and side hill at the same time! Had to avoid the wetspot in the middle, standing water there!
RayP(MI)
04-25-2007 18:03:23
 Re: David in Wales - late entry - plowing contest in reply to RayP(MI), 04-25-2007 17:59:52
third party image
Here's the tractor and plow. Certainly not an impressive rig... Sure doesn't hold a cnadle to the rigs you were showing.
KIP in MX
04-26-2007 09:35:34
 Re: David in Wales - late entry - plowing contest in reply to RayP(MI), 04-25-2007 18:03:23
Is that a Super C? Must have taken awhile to plow that patch.
dds-inc
04-25-2007 18:54:25
You're supposed to plow sod with coulters. If you had've used coulters, you would have a much smoother looking job because they slice the grass
Allan In NE
04-25-2007 18:16:59
Excellent, excellent Job!
Yes, that sod will make ya cuss yer mother. If you dual up the disc tractor, it will make the ride "somewhat smoother". (not much tho). :>)
I like your outfit and it looks as tho it really did a number for you.
Well Done!
Allan
RayP(Mi)
04-25-2007 18:28:11
 Re: David in Wales - late entry - plowing contest in reply to Allan In NE, 04-25-2007 18:16:59
Alan - Field is "rough as a cob." I hurt all over!
Gonna hurt all over again when I get to disking!
Gene Dotson
04-25-2007 18:38:39
 Re: David in Wales - late entry - plowing contest in reply to RayP(Mi), 04-25-2007 18:28:11
Ray;
I had some rough plowed ground a couple of years ago. I hooked my 12 foot disc behind my Case 320 dozer and went over it the first time. That was a very smooth ride as the tracks stayed on top of the clods. Not very fast, but was a fun job... Gene
