Tractor Talk Discussion Forum
john deere 6030 transmission oil pump
francis pawelek
04-26-2007 19:44:53
hi guys,is this located under the top transmission cover like on the 7020?or right under the rockshaft area?thanks
justfixin
04-26-2007 19:51:31
 Re: john deere 6030 transmission oil pump in reply to francis pawelek, 04-26-2007 19:44:53
it is on the front of the transmision behind the clutch housing, (in the split)
francis pawelek
04-27-2007 06:02:11
 Re: john deere 6030 transmission oil pump in reply to justfixin, 04-26-2007 19:51:31
does it need to be split?or can i get to it by raising the rear rockshaft,or transmission cover?i'll check in with you afterwhile
Glen in TX
04-27-2007 12:32:08
 Re: john deere 6030 transmission oil pump in reply to francis pawelek, 04-27-2007 06:02:11
You have to split it at the trans and clutch housing to get it out.
francis pawelek
04-27-2007 13:40:34
 Re: john deere 6030 transmission oil pump in reply to Glen in TX, 04-27-2007 12:32:08
ok i'll check it out ,most guys told me i should be able to get it from under the rockshaft cover too maybe,,,its the 2 geared pump,thanks glenn,,,gotta head to karnes city tex at farm
Glen in TX
04-27-2007 21:50:05
 Re: john deere 6030 transmission oil pump in reply to francis pawelek, 04-27-2007 13:40:34
It mounts to and drives off a splined shaft in the front of trans not down inside like others. Read the technical manual for 6030 and it says SPLIT the tractor! If cab, floor plate and heavy rock shaft all need to come off well go ahead but you'll still end up having to split it. http://techpubs.deere.com
