Tractor Talk Discussion Forum
ROCKER ARM HITTING VALVE COVER
alan bane
04-27-2007 07:57:58
Just had a head gasket put on and had the head shaved and now I have a Rocker arm hitting the valve cover. What to do?
shrk
04-27-2007 10:13:09
 Re: ROCKER ARM HITTING VALVE COVER in reply to alan bane, 04-27-2007 07:57:58
Like he said before the push rod isn't seated right, and as far as shaving the head you can do that,thats why theirs adjustable tappets on the rocker arm.
Rick in Michigan
04-27-2007 09:53:10
My guess - if it's only one hitting, you don't have the pushrod seated in the lifter - it's up on the edege of the lifter causing the rocker arm to raise up higher on each rotation of the cam.
Probably wrong - usually am.
supergrumpy
04-27-2007 08:27:43
can you grind down the pushrods??
alan bane
04-27-2007 09:00:05
 Re: ROCKER ARM HITTING VALVE COVER in reply to supergrumpy, 04-27-2007 08:27:43
Yes ,some, maybe 1/16 of an inch. I only have one hitting.
RAB
04-27-2007 08:05:59
Shaved to increase the compression? How much? If you do that your valve gear geometry is all messed up - push rods not at right angle, rockers bearing at wrong angle etc.
You need to fit appropriate spacers below the rocker arm pedestals to return the angles to design.
RAB
alan bane
04-27-2007 08:16:42
 Re: ROCKER ARM HITTING VALVE COVER in reply to RAB, 04-27-2007 08:05:59
Blew a head gasket and had a warped head.
msb
04-27-2007 08:02:56
What engine? Hydraulic lifters? What?
