Tractor Talk Discussion Forum
case 470 diesel parts
Emo
04-27-2007 13:34:08
Hi there.
I need outside tie rod ends and power steering cylinder for my 1972 Case 470 diesel tractor.Also, rosa master fuel pump is dripping fuel from the shaft hooked to a throttle lever.
This is very good machine. Any ideas where to find parts and how to fix the pump?
georgeky
04-27-2007 16:41:47
 Re: case 470 diesel parts in reply to Emo, 04-27-2007 13:34:08
Have you checked with a Case IH dealor for the tie rod ends. Any diesel injection shop can fix the pump. There is a couple of O rings on that throttle shaft that are probably causing the leak.
