Tractor Talk Discussion Forum
wide front rims for 6030 john deere
francis pawelek
04-29-2007 18:42:57
what type of rim should i ask for up front cause i'd like to have very wide front tires,at least a foot or close,would any other tractor rim interchange?
Glen in TX
04-30-2007 10:47:53
 Re: wide front rims for 6030 john deere in reply to francis pawelek, 04-29-2007 18:42:57
You'll want some 16.1 rims which should be available in 11,14,16,& 18" widths with 8 hole 6" center pilot hole or 6.010" center hole. 6030 used 9.50-20 tires on row crop models on 7x20" rims. Standard tractors and combination used 11.00-16 tires or larger 14L-16.1 tires or 18L-16.1 tires. Find some of the larger tires and then whatever rim width in 16.1 wheels tire manufacturer recommends for them. Also be aware you may find those tire sizes in tube type or tubeless so get rims that will work for tubeless if that's only kind of tire you can find. JD no longer shows specs or prices for those larger rims for 16.1 but might also try salvage yards in Kansas or other large wheat growing areas because regular implement wheels may not have the correct offset needed and tires could rub on steering arms.
francis pawelek
04-30-2007 12:43:43
 Re: wide front rims for 6030 john deere in reply to Glen in TX, 04-30-2007 10:47:53
glenn where are you in this state?near dallas?i just wonder if i put an ad out in wanted section i'd be able to find some?i was asking about that noise my friend heard right befor he shut it off ,seems to him it was the same sound my 7020 made 2 weeks ago,,anyway he started it back up and drove it closer to home after it happened,think it was his transmission pump too?i've heard of their rockers backing off but yet i've heard and seen the trans oil pump break and the tractor still run and drive too,glenn send me your email adress so i have a jd texas friend,latr francis
Glen in TX
04-30-2007 13:06:56
 Re: wide front rims for 6030 john deere in reply to francis pawelek, 04-30-2007 12:43:43
Sent you email Francis.
