Tractor Talk Discussion Forum
Horsepower for baler with thrower
Don't know much
05-04-2007 11:27:20
How much horsepower do I need to operate a baler with a thrower?
The ground is pretty flat.
Thanks for the help.
Don't know much
05-04-2007 19:30:29
 Re: Horsepower for baler with thrower in reply to Don't know much, 05-04-2007 11:27:20
third party image
Here is a picture of the land. I have a Allis WD45, and a John Deere A. The A is an all fuel aprox 29 hp, and the Allis might be a bit lighter but has the hand clutch and 43 hp.
Do I have enough tractor, or should I tell the wife, you all said I needed another?
low budget
05-05-2007 08:44:17
 Re: Horsepower for baler with thrower in reply to Don't know much, 05-04-2007 19:30:29
You always need another tractor
RayP(MI)
05-04-2007 17:41:51
We regularly operate a Hayliner 268 - without thrower with a John Deere B, pulling haywagon behind. Only get in trouble a few times on steep hills. Have used the same rig behind a Farmall 200, but it is a bit light for that service. Engine will pull it OK, but you will run out of traction. Would like a bigger tractor, but you "run what you brung." Live pto is nice, but you can do it without, if you"re careful.
the tractor vet
05-04-2007 17:26:32
Baled many of bale with a 269 New holland with a kicker behind a Farmall 450 diesel. and never ran out of pony power at times though a full wagon and the hills around here would make for some seirous pucker factor. when the load would start shoven ya .
showcrop
05-04-2007 16:42:56
just want to emphasize what others have said. In order to maintain control on a slope, weight is much more important than power.
old
05-04-2007 13:23:32
A lot depends on what baler you want to use. I pulled a JD-14T with thrower behind my Oliver 77 which is 38HP and it played with it. Plus I have a very heavy wagon behind the baler with 2 or 3 kids on the wagon stacking it as the bales flew back to them. That was on rolling land not big hills but not small either.
dds-inc
05-04-2007 13:02:01
I'M glad you said it was flat, because if it WEREN'T, you would be in the market of a 55 or 70 horsepower tractor with big weights on the rear tires.
I would recommend a tractor about 45 or so horsepower but would have a relatively ballasted tire/weight combo. Any year tractor should work, but live PTO and HYD. is a MUST!
hope i can help.
mjbrown
05-04-2007 12:22:37
You can operate that with a 40hp tractor. Add a wagon loaded with hay and you can find yourself wishing for a bigger tractor unless it is nice and flat, especially going down hill.
