Tractor Talk Discussion Forum
JD 1050 coolant spray
Tookyflyer
05-05-2007 19:02:26
Help. Just bought a JD 1050. After about an hour of light work, I noticed the coolant tank behind the radiator was leaking out of the top. The fluid level was way above the full mark, filling the entire tank. After it cools I plan to draing the fluid and see how much is in there (I am hopeful to find a great deal more than the 6.5 quarts required). Here"s the question - has anyone had the same problem due to a simply over filled radiator and tank? How do I know if I am looking at a bigger problem? Thanks.
Scott (NH)
Farmall MD nut
05-06-2007 16:04:48
 Re: JD 1050 coolant spray in reply to Tookyflyer, 05-05-2007 19:02:26
Hi Scott. Is it gas or diesel? We got a 4 wd 1050 3 cyl diesel turbo, never had a problem. Only problem we've had is their damn starter. It sounds to me like you have a bad head gasket. I hope not but that's what it sounds like.
