Tractor Talk Discussion Forum
JD 7100 Planter help
Larry806
05-10-2007 18:37:54
I bought a 15 row 15 inch planter . The guy I bought it from said he had the manual now he can"t find it . My dealer said they can"t get one either . Can anyone give me the gear settings for seed rate? I"m wanting to start planting beans tomorrow and don"t have any idea where to set it . I would need the different settings for 70 lbs to 120 lbs per acre . If anyone has a book could you post the drive & driven gears to lbs to acre Thank you Larry
Glen in TX
05-10-2007 22:19:18
 Re: JD 7100 Planter help in reply to Larry806, 05-10-2007 18:37:54
They show some downloadable manuals so maybe have what you need?
paul
05-10-2007 20:18:33
You need a better dealer. Manual should be easy to get.
Now, you have 2x the planter units, and after-market bean meter that also needs a manual from Kinze - so you have to do a bit of math, but still, they should have a manual for you for a 7100 in 48 hours if you want.
--->Paul
JD 7000
05-10-2007 19:09:33
First we need to know if you are running JD seed cups , JD radial meters or Kinze radial meters.
Larry806
05-10-2007 19:18:49
 Re: JD 7100 Planter help in reply to JD 7000, 05-10-2007 19:09:33
Kinze radial
Gerald J.
05-10-2007 19:55:17
 Re: JD 7100 Planter help in reply to Larry806, 05-10-2007 19:18:49
Kinze count the seed, not the pounds. 60 beans per shaft revolution, corn rate times 5. I suppose you really want some where about 165,000 seed per acre, then you want the corn rate for 33,000 seed per acre. I don't have the book in the house (same as 7000 often on epay) but as I recall that would be 14 driver 11 driven if 2040 chain or 28 driver 22 driven in 40 chain or sprockets. With 7.60-15 drive tires. 11:11 gives 26100 corn, so 14:11 gives 33,218 corn or 165,091 beans.
And if the bean count 3000 per pound that's 55 pounds per acre.
Oh, that's 30" rows. 15" rows you want to slow it down by 2, going to 11 driver 14 driven, or something like that.
Figuring closer 9 driver 14 driven gives 33557 on 15" rows of corn or 167,786 beans. 8 driver 13 driven gives 160,615, 9 driver 13 driven 180,692.
If 3000 per pound that last rate is 60.23 pounds per acre, if 2500 per pound that is 72 pounds per acre. I find the Kinze units count precisely.
Gerald J.
