Tractor Talk Discussion Forum
O/T F 350 auto trans
37 chief
05-10-2007 18:38:35
On start up my truck doesn't go foreward in any gear for about 10 seconds. This has only happened a couple times in the morning . It had a complete flujid change about 10 K ago. Any thoughts. Stan
jdemaris
05-11-2007 05:54:26
 Re: O/T F 350 auto trans in reply to 37 chief, 05-10-2007 18:38:35
I don't know what year and trans you have. My 94 F250 diesel had a similar problem with the E40D auto-overdrive trans - and it ended up being the electric switch sticking. I had a time lag whenver I shifted, especially when cold. Seems there is no mechancial connection with the shifter to the trans - at least with my 94. An electric switch by the steering column sends a signal to the trans. In most other cases I would of suspected cold oil, half-plugged intake screen, etc. as others have already mentioned.
Cliff Neubauer
05-10-2007 19:47:39
Did they flush the system when they changed the fluid or did they just drop the pan? I've heard several very experienced transmission guy's say that it's very common for a transmission that's had the system flushed to have problems 8,000-10,000 miles later because the flushing process loosens up crud in the lines and transmission that eventually end up in the filter.
37 chief
05-10-2007 22:57:52
 Re: O/T F 350 auto trans in reply to Cliff Neubauer, 05-10-2007 19:47:39
I did the work myself. When I rebuilt the motor I removed the torque convertor to drain it, and replace the seal. I removet the pan and a new filter was installed. I will never have my transmission flushed. Stan
NEsota
05-10-2007 19:42:11
In a colder climate than yours, I had similar symptoms, at start up on a Ford 302 w/auto. Shop told me the problem was a hardened lip seal in the valve body. The Ford automatic will warm up fastest (I think) when it is in reverse. Fluid is under more pressure.
Bob
05-10-2007 22:33:57
 Re: O/T F 350 auto trans in reply to NEsota, 05-10-2007 19:42:11
"a hardened lip seal in the valve body"...
Did they also offer to ell you the Brooklyn Bridge?
Allan In NE
05-11-2007 03:08:47
 Re: O/T F 350 auto trans in reply to Bob, 05-10-2007 22:33:57
I think it's called ICDF.
"Instantaneous and Creative Diagnostic Fabrication". :>)
Allan
Allan In NE
05-10-2007 18:54:50
Stan,
Tomorrow morning, start the truck, let it idle for 10 or 15 seconds in park/neutral, then drop it in gear and see if it immediately goes into gear.
Normally, your symptom is a plugged filter, but if you've just had it serviced, I really doubt if that is the problem.
Sounds more like the converter/pump bushings are a bit loose and the converter is draining down overnight.
Allan
Super Steve
05-10-2007 18:44:34
When my car started doing that it was only about 5000 more km and the tranny said that was enough. But have u checked the fluid level? maybe once it warms up and expands a bit theres enough to get u going. just a thought.
