Tractor Talk Discussion Forum
Hydraulics for Farmall B
sshev
05-11-2007 10:41:16
I"d like to add live hydraulics to my B Farmall, preferably driven off the distributor. Would a pump from the H"s and M"s with that set-up work on a B? If not, is there one that would?
thanks
georgeky
05-11-2007 12:02:52
 Re: Hydraulics for Farmall B in reply to sshev, 05-11-2007 10:41:16
If you are handy it can be done with a power steering pump off an old truck or car. You will have to make mounting bracket, but I have seen several set up this way, and work well enough.
Steven@AZ
05-11-2007 11:34:14
The live pump from the H and M is completely different than what a B would require.
You would need a block, pump, etc. from a Super A or newer that came with live hydraulics to make it work that way.
The easiest way would be a belt drive from the crankshaft or run a shaft out the front direct from the crankshaft.
Here is my non-live hydraulic setup on my A:
third party image
third party image
