Tractor Talk Discussion Forum
new prince hydraulic pump ,,resorvour location
phil lowe
05-11-2007 19:47:31
I must be working too many hours at work cause Princess Auto had a prince PTO pump 21 gallon on sale for $600 .WEll I bought it with only half a mind what I was gonna do with it.THought I'd run the big 6 " log splitter ram with it as still didn't get that gear drive thing figured out ,Also thought I'd now be able to run the front plow and rear blade at same time for snow plowing ..3000 only allowed one or other to be used ...NOW I gotta get a 20plus gallon resorvour geared up ..no biggy ,I got couple old water tanks I figure I'll weld up ,,,or may just start from scratch so it'll fit better..
so I'd like to mount it on front of tractor and run lines back ,,this will give me counterweight and more room out front..I think it's gotta be mounted above right?
words of wisdom requested .I am real busy at work for the next few weeks so this is the design stage ..Will this pump work good on my wood splitter ,,??? 6" cylinder,, so tractor pump was way to slow
135 Fan
05-11-2007 20:25:11
 Re: new prince hydraulic pump ,,resorvour locati in reply to phil lowe, 05-11-2007 19:47:31
Having the reservoir above is best as it causes a flooded inlet. However with careful priming it can be below the pump. You don't want to have too long a suction line or block your radiator if you leave the tank on all the time. This could cause the tractor and/or hydraulic tank to overheat. Make sure the tank is absolutely clean so it doesn't damage the pump. You need a filter and preferrably a suction strainer in the tank. Hope this helps. Dave
BarryfromIA
05-12-2007 05:16:11
 Re: new prince hydraulic pump ,,resorvour locati in reply to 135 Fan, 05-11-2007 20:25:11
Don't forget the filter.
