Tractor Talk Discussion Forum
engine running like crap
dhutton
05-12-2007 13:20:58
i have a simplicity 6216 runs fine when first started but within a couple of minutes (about 5)it starts running very poorly,you have to play with the choke,and eventually keep it choked just to keep it running,and eventually just dies.fuel filter is good,and it is getting fuel as far as i know .but solenoid is shot,was wondering if this has anything to do with engine control.....i am lost
RN
05-12-2007 13:30:16
 Re: engine running like crap in reply to dhutton, 05-12-2007 13:20:58
Solenoid shot? You mean fuel shutoff solenoid on carberator? This can cause big problem, clean carb and check- plunger should retract on solenoid when electric current applied- use test jumpers. JD Sabre had about same problem- manual shutoff put inline and plain plug used temporary in carb until replacement solenoid found. Also check wiring to solenoid- dealer recommended, notes wires sometimes tugged out. RN
dhutton
05-12-2007 13:37:55
 Re: engine running like crap in reply to RN, 05-12-2007 13:30:16
fuel shutoff solenoid seems to work can hear it when key is turned on and off,solenoid by battery is shot though,would that do anything
Farmall MD nut
05-13-2007 03:10:24
 Re: engine running like crap in reply to dhutton, 05-12-2007 13:37:55
No, that solenoid is for the starter. I would say if the fuel solenoid is good, check for dirt in the carb, or your coil(Spark) is goig bad.
Farmall MD nut
05-12-2007 13:25:36
I'd say it's probably 1 of 2 things. Either you got dirt in the carb, or your coil is heading south.
dhutton
05-12-2007 13:34:06
 Re: engine running like crap in reply to Farmall MD nut, 05-12-2007 13:25:36
isnt that the solenoid
Farmall MD nut
05-12-2007 13:35:52
 Re: engine running like crap in reply to dhutton, 05-12-2007 13:34:06
Sorry, That's what I meant
