Tractor Talk Discussion Forum
not a tractor but still a motor
colby[In]
05-12-2007 17:49:59
took off valve cover this is what i seen on my 5hp motor this why i have no comp. ? any ideas on wht i need to do?
third party image
thanks
CRUSADER
05-13-2007 07:37:59
 Re: not a tractor but still a motor in reply to colby[In], 05-12-2007 17:49:59
Make sure that the fastener that holds the rocker arm is good, I almost did an engine overhaul on an old pickup a few years ago becuase the nut on the rocker arm came loose and the cylinder didn't have any compression. The older gentleman told me that it was either a blown head gasket or a burned valve and needed either an overhaul or complete rebuild. I did some checking and found something simular to what you have here. Fixed the problem (and a few others the pickup had) and the customer thought I was the wizard of the GM engine and the 60's thru early 80's GM cars and pickups.
Jim
ErnieDD
05-12-2007 18:16:28
The rocker arm on the right is off the valve. The valve is probably the intake, and stuck from setting. When you tried to start it you bent the pushrod allowing the rocker arm to unseat.
Free up the valve, replace the push rod, and set the valve lash to spec.
