Tractor Talk Discussion Forum
rusted manifold
kyle in NY
05-13-2007 06:09:56
I would like to replace the manifold on my IH 2444 but it is very rusted and one bolt has rusted to the point where it is just a round nub. Any ideas before I tear into it and start cussing. Thanks.
David Snipes
05-14-2007 11:47:59
 Re: rusted manifold in reply to kyle in NY, 05-13-2007 06:09:56
When you put new studs or bolts back in, use a good high temp anti seize compound so the next guy won't be cussing so much.
jonathan s
05-13-2007 18:31:29
ok this is what i had to do on my john deere b. i snapped off all the nuts.(not on purpouse) and then the manifold was so rusted to the head that i ended up hitting it with a hammer to break it into pieces. then trying to get the studs out i also snapped them flush with the head. i had my older brother take it to work with him and he heated up the head and got the remaining studs out. just remember if u break it into pieces you will have to clean out the inside of the head of any pieces of metal. just my tow cents. jonathan s
Heyseed
05-13-2007 16:03:19
If the engine is still running and IF you can get a grip on the bolt with vice grips. Run the engine till good and hot then try to back the bolt out. If you can not get a grip use the grind off method. Good luck, PS I have tried the cussin method and it didnt work.
kyle in NY
05-13-2007 13:57:29
Thanks for the valuable info. Kyle
Howard H.
05-13-2007 06:21:46
Grind the head off of the bolt - when the manifold comes off, then you'll have a stem to work with for getting the stud out of the head.
Howard
bill mar
05-13-2007 06:19:56
if the manifold is no good,could you break the casting away and expose the bolts where they meet the head and then heat them with a torch?
Steven@AZ
05-13-2007 08:58:04
 Re: rusted manifold in reply to bill mar, 05-13-2007 06:19:56
Do NOT heat the head with a torch!!! You will crack it for sure.
Grind the head off the bolt, remove the manifold and you will have a stud to work with. If a ViceGrip doesn't work, you can weld a nut on the end of it.
