Tractor Talk Discussion Forum
Leyland hydraulics
Larry A Macon
05-14-2007 07:04:12
I have a 60 HP Leyland tractor and the three point will not go down. Raises fine, but will not even leak down after months of sitting with a large box blade attached. Any help would be appreciated.
Super Steve
05-14-2007 09:01:43
 Re: Leyland hydraulics in reply to Larry A Macon, 05-14-2007 07:04:12
Just above the 3pt is a half ball looking deal that is held on with a nut in the center pull it up and turn it a few degrees. we had a 4/65 nuffield and a 344 leyland that both had them and every once in a while u had to play with them. u may have to try it a couple times until u find the right spot.
Old Timer John
05-18-2007 01:08:29
 Re: Leyland hydraulics in reply to Super Steve, 05-14-2007 09:01:43
There is a 'Flat' on the cap with a corresponding 'Cutaway' on the top cover. Lift the cap, rotate until the 'flat' and the 'cutaway' align. this is the 'Free' position.
Never transport an implement with the lock engaged. it will damage the casings! It is to hold the unused linkage 'Up'
