Tractor Talk Discussion Forum
Re: Zen-noh Will Not Start
souNdguy
05-14-2007 08:21:59
Zen Noh Is just a big farming co-op that buys tractors from other manufactures and re-badges them for their own use.
What flavor do you have? is it orange? kubota.. Or green or red.. Yanmar? etc.
The more info you post.. the better the answers will be.
Did you replace battery cables, and clean the ground up real good?
Soundguy
fctractor
05-14-2007 08:45:45
 Re: Zen-noh Will Not Start in reply to souNdguy, 05-14-2007 08:21:59
Yep, replaced cables, no corrosion on any cable. The tractor is orange (kubota). ZL2000FD.
souNdguy
05-14-2007 12:17:30
 Re: Zen-noh Will Not Start in reply to fctractor, 05-14-2007 08:45:45
If the tractor battery was dead, then you may not have been able to jump battery to battery due to the load of the dead battery. If it was a good battery, and you were able to jump starter to doner battery. that means starter is good.
My next thought would be starter solenoid... Jump around it with tractor in neutral and clutch locked down.. if that works.. get a new solenoid.. A universal ( solenoid is grounded thru base and requires key-hot to crank ) or an isolated ford type will work ( Solenoid is isolated from ground, key-hot to one small terminal.. other small terminal to ground ).
Soundguy
