Tractor Talk Discussion Forum
broken farmall
Ray Necci
05-14-2007 08:23:13
I have a Framall Cub tractor Model-FCUB S/N-5634 that when the clutch is depress and the transmission is in gear thractor makes a loud high pitched grinding noise that seems to be comming from the clutch housing area. The tractor operates as normal when the clutch is released. Any suggestions on what the problem may be?
Ray Necci
05-14-2007 18:55:27
 Re: broken farmall in reply to Ray Necci, 05-14-2007 08:23:13
one more thing, actually the through out bearing is what I was thinking but the noise is so loud I didn't really think it could be it (really loud!)
Don L C
05-14-2007 18:45:18
Sounds like the throwout bearing....best to replace the clutch disk, pressore plate, throwout bearing and reface the flywheel while you are at it....
HAPPY DEERE
05-14-2007 13:58:23
i thought all farmalls were broke Just kidding =)
Stan(PA)
05-14-2007 08:26:10
Sounds like the Throwout (Clutch release)bearing to me.
RustyFarmall
05-14-2007 08:25:27
You need a new throw-out bearing.
Wardner
05-14-2007 18:42:59
 Re: broken farmall in reply to RustyFarmall, 05-14-2007 08:25:27
It could also be the pilot bushing in the end of the crankshaft.
Actually, I don't think it is the throwout bearing unless the original cheap graphite bearing has been replaced with a ball bearing. I don't think the graphite bearing can "squeal", but what do I know.
Either way, replace it as soon as possible. The vibration is enough to cause metal fatique and breakage on the wimpy and long draveshaft.
Ray Necci
05-14-2007 18:49:14
 Re: broken farmall in reply to Wardner, 05-14-2007 18:42:59
I had the tractor gone over about 7 years ago they may have put a cheap bearing in it. thanks
John M
05-14-2007 18:54:49
 Re: broken farmall in reply to Ray Necci, 05-14-2007 18:49:14
Its not nessarily a cheap bearing, its just grafite as opposed to a roller type bearing. When serviced properly they can last for a good while.They are greasable and the grease just kinda seeps out of the grafite. If you have never greased it, then I have no doughts its wore out. The one in my 49 Cub is about 19 years old, and although it hasnt seen any serious work in about 4 years its still working fine.In fact the clutch facings went before the bearing did.Dealer has the roller type replacement for the grafite type.
Pasppy
05-14-2007 16:29:01
Yep----Rusty Farmall has it nailed. Just Do It!!
Stan(PA)
05-14-2007 08:27:26
Seems like you are a fast typer Rusty :)
Ray Necci
05-14-2007 18:46:28
 Re: broken farmall in reply to Stan(PA), 05-14-2007 08:27:26
Thanks for the help all
