Tractor Talk Discussion Forum
JD verses Farmall Rims
biggerred
05-14-2007 17:57:27
Arn't the double bevel rims (11X38) that are on the 60 up to a 730 Deere interchangable with those of the 400 and 450 Farmall?
ChadS
05-15-2007 06:49:41
 Re: JD verses Farmall Rims in reply to biggerred, 05-14-2007 17:57:27
Deere rims fit the 450 cast hubs and vice versa. I just got done putting a set of deere rims on 450 centers. Made a nice setup! I used 826 driving lugs instead of the 450, bit heavier and they use larger bolts for the power the ol M has got. Wide selection of different widths that will bolt on. 14, 16, 18 20 22 inch wide rims. Not as easy to switch as 9 bolt pressed steel, but, it works and I dont have to cut and weld a set up. Chad
oliver power
05-15-2007 02:26:16
I don"t think I"d recognize the name if I herd it. But , I do know there use to be a rim manufacturer which sold rims to many brand tractors. Deere , Oliver , Farm-all , etc..
dds-inc
05-14-2007 19:38:10
never thought of that. I think the rims were originally made by firestone and deere and farmall made their own hubs to fit in the centers. I'm pretty sure they are interchangable!
iowa_tire_guy
05-14-2007 18:59:43
Yes they do, only the paint is different.
John M
05-14-2007 18:48:58
Yep, and if ya get them at the Deere dealer they are going to charge you twice as much!!:)
in-too-deep
05-14-2007 18:17:20
It would make sense that they do. 10x38's from a Farmall H will fit a JD B nicely. I bet it's the same for an 11".
MikeinKY
05-14-2007 18:01:29
I think they are.
