Tractor Talk Discussion Forum
carb. mixture screw
fred h. covey
05-15-2007 19:02:18
screw for mixture on carb. if i take it complety out it runs fine put it back and it run out of gas and dies. this is on an 8nford tractor.thanks
dave guest
05-16-2007 19:22:07
 Re: carb. mixture screw in reply to fred h. covey, 05-15-2007 19:02:18
Put a little shot of carb cleaner in screw hole and leave long as possible, then a little compressed air. Works sometimes. Worth a try.
old
05-15-2007 19:21:10
That problem is caused by a clogged up air vent in the carb. The float bowl has a vent in it and when clogged they will run with the main jet out but not run when its in. Its not really running out of gas but causeing a vacuum in the float bowl so then it can't pull the gas into the engine as it should. Only fix for that is to rebuild the carb
