Tractor Talk Discussion Forum
O/T Ford 9 Diff
richard in nz
05-15-2007 21:36:36
I normally spend my time servicing and repairing Claas and J.C.B. equipment here in NZ, now, the group parts manager where I work is building a Hot Rod, "32 Ford chassis, and has asked me to build up the drive head for the rear axle. Its a Ford 9" diff, he has got a Richmond instillation kit brought over from the USA. Do any of you know what the crownwheel bolt torque, Pinion shaft nut torque and bearing preload for the pinion shaft and diff bearings is, also the backlash setting so I can build it up for him? Thanks for any help!
Greg_Ky
05-15-2007 23:08:59
 Re: O/T Ford 9 Diff in reply to richard in nz, 05-15-2007 21:36:36
If it is going to be a show car use the crush sleeve. If the motor has some snort and he will be running it hard set it up with solid shims.
richard in nz
05-15-2007 23:55:14
 Re: O/T Ford 9 Diff in reply to Greg_Ky, 05-15-2007 23:08:59
A crush spacer sleve has been supplied, but this thing has a stonking great V8 going in it with a supercharger! I will have a word with him tomorrow morning when I get to work!
Bob
05-15-2007 21:45:55
Here's a couple of links:
Link
Link
