Tractor Talk Discussion Forum
Shop lights
oldoliverlover
05-17-2007 08:18:35
Building 24x40 shop to restore/repair old tractors. What is best kind of lighting to put in. Can't see nearly as well as I used too : )
comfortking
05-18-2007 04:33:10
 Re: Shop lights in reply to oldoliverlover, 05-17-2007 08:18:35
Place some four foot lights on the walls where you are working. Much of your work is done on the sides of tractors. We only have a few on the walls but plan on putting more
big jt
05-17-2007 23:08:58
I will back up what the rest say. 8' flourescents and plenty of them.
In my 40 X 54 I originally used two rows of 3 double bulb fixtures each. Later added two fixtures crossways and will eventually add two more. Have two of those fixtures over the bench, one in the office, a four foot over the welding bench and another over the lathe. Also some task lighting.
MarkB_MI
05-17-2007 19:54:45
My 30x40x10 shop has six 8 foot T8 flourescent fixtures. They are arranged in two rows, each row 7-1/2 feet from the side wall. (In other words, 25% of the way in from each side.) I have them switched so that I can use just the two middle fixtures, just the four outer fixtures or all six. Four lights are usually good enough to work by, but I run all six anytime I need to see well.
I got the T8 fixtures at Home Depot for about $43 each (about four years ago). Don't confuse these fixtures with the slightly more expensive commercial T12 fixtures also carried by HD. The T8 fixtures are supposed to be more efficient than the T12 units.
Although the T8 fixtures work well in cold temperatures, I haved them backed up by four 150 watt halogen lights. When it gets cold, I use the halogens until the the flourescents have a chance to warm up.
Gary from Muleshoe
05-17-2007 17:09:02
In a shop that size i would definitely install 8' fluorescents. T-8s are more energy efficient, but more expensive to buy. T-12 will use a little more energy, but cost less to buy. If you have some salvage yards that resale this type of stuff you could buy used. For the money in the long run I would put in T-8s, bulbs last longer also.
Marv
05-17-2007 15:45:31
T8's floresent lights are great. Get them in four foot lengths. I've installed reflectors also.
omahagreg
05-17-2007 14:21:33
I had my electrician install the high output cold start 8' in my new garage 2 years ago. Very happy with the light and how they start even when cold! I have not had to buy new bulbs though, that might make me flinch! Greg
dds-inc
05-17-2007 14:03:59
about 9 of those 8 foot HIGH OUTPUT cold start flourescent lighting with 90 watt bulbs. Each string of three is on a switch. I tell you what, i have a 24x28 shop, and I can see SOOOOO well that i DON'T need a workbench light.
Midwest redneck
05-17-2007 13:55:50
What ceiling height do you have.? When I wired in my garage, with 8foot ceiling I wired in several outlets in the ceiling that work off of a light switch and I have the 3 prong plug in sockets in the ceiling with regular bulbs in the sockets, nice and cheap.
neblinc
05-17-2007 09:58:15
There are lots of factors in determining your lighting needs. Ceiling height, number of lumens, budget.
I went with the T8 bulbs in a 4 bulb surface mount fixture using 5000 kelvin bulbs. I think I have 24 fixtures in my 40 x 50 shop with a 12 foot ceiling and it is really bright. If you have a local lighting company, they have software that will give you all the specs and layout.
I was lucky and found my fixtures used, got them for less than half of new, just had to pay more for bulbs, but they are rated for 10,000 hours.
My walls and ceiling are white and a light gray floor so that helps also.
Randy
oldoliverlover
05-17-2007 11:40:55
 Re: Shop lights in reply to neblinc, 05-17-2007 09:58:15
Pic look great - I'll have white walls & ceiling as well. Will only heat when I'm in it Thanks
neblinc
05-17-2007 10:01:47
Forgot to mention that all my fixtures have the electronic ballast so they are very quiet. If your shop will be un-heated that will make a difference also in the type of ballast you use.
Randy
glennster
05-17-2007 09:55:05
we use 8 ft flourescents, t-12 double bulb fixtures in our shop, the cold temp fixtures with the reflector hood. the big box store fixtures leave a little to be desired, the ballasts burn out pretty quick, get the good ones from an electrical supply store if youre gonna use em. they use the single pin on the end of the bulb.
