Tractor Talk Discussion Forum
'97 Dodge Ram 4WD Knock
Tweeter
05-17-2007 16:08:19
I posted here before about a clicking noise from the front of my 1997 Dodge Ram pickup. It happens when I let off the gas pedal and coast. I hear a click,click,click, etc. with a squeal sometimes until I give it gas. If I put it in 4wd, the noise goes away. I was under the truck today and rotated the front drive shaft and can here the click in the transfer case.
Roy Suomi
05-17-2007 17:41:52
 Re: '97 Dodge Ram 4WD Knock in reply to Tweeter, 05-17-2007 16:08:19
I had a '98 1500 4x4..The vacuum operated shifter on the front axle went bad and kept the axle shifted partially into axle lock position..It made all kinds of strange noises
Don L C
05-17-2007 16:40:08
Tweeter ---
Check these things ----the front "U" joint,look for a slight shiney place around the joint. this would come from the joint moving with a bad bearing.
next, jack up a front wheel,wiggle the front wheels back and fourth, top to bottom....your looking for slopp in the bearings....
check the lug nuts, be sure they are tight.....
Tweeter
05-17-2007 17:02:20
 Re: '97 Dodge Ram 4WD Knock in reply to Don L C, 05-17-2007 16:40:08
I just torqued them to 95ft lbs and they were good.
Tweeter
05-17-2007 17:01:25
The lug nuts are tight. Both front wheels wobble when wiggle them. The U-joints look ok.
Aaron Ford
05-17-2007 16:20:59
This typically means you have a wheel loose. When the lugs are not tightened, they tend to make a click-click or a clatter upon letting off the accelerator. Hope this post is in time. Aaron
Tweeter
05-17-2007 16:24:24
 Re: '97 Dodge Ram 4WD Knock in reply to Aaron Ford, 05-17-2007 16:20:59
Are you serious?
