Tractor Talk Discussion Forum
dead electrical system
kyle in NY
05-18-2007 09:38:42
I was working on the old IH 2444 last night and forgot to switch off the ignition. Realized an hour or so later and switched off. Then noticed that I had no power at all and the battery is still fully charged? Dash lights do not operate nor will the starter turn. Any ideas? Does anybody know if this tractor has a fuse block that I have not found yet? Thanks, Kyle
glennster
05-18-2007 09:49:05
 Re: dead electrical system in reply to kyle in NY, 05-18-2007 09:38:42
get a 12v test lamp, put the ground on the tractor, and start chasing the positive side from the battery back, when the test lite doesnt light, you found the problem. not sure but i think that there is an inline fuse behind the dash.
ldj
05-18-2007 09:44:43
First thing I would try if you don't have power any place past the battery is to make sure battery terminals are good clean and tight.
