Tractor Talk Discussion Forum
Need fluid info on IH 340 Utility
Tawn
05-19-2007 13:20:35
I'm waiting on my manuals to come in...can't help but tinker with my 1958 (serial # 908) 340 utility tractor that I just bought. It has several small leaks here and there and seems to be OUT of hydrolic fluid. I've put 5 gallons in it and still not flowing out of check hole on left side of transmission. Anyone know the capacity for this tractor? I don't want to put in too much...the hydrolics are working tho I haven't tried to lift any implements yet. Thanks!
Russ from MN
05-19-2007 16:06:58
 Re: Need fluid info on IH 340 Utility in reply to Tawn, 05-19-2007 13:20:35
We had one, and I changed the filter once, seems it held 12-15 gal.
Tawn
05-19-2007 16:19:03
 Re: Need fluid info on IH 340 Utility in reply to Russ from MN, 05-19-2007 16:06:58
Thanks, after I kept adding and adding and adding I was starting to get worried. Especially since someone on another site had posted something about it holding about three gallons! I did try lifting my bush hog and the lift seems slow. Do you know if that's normal?
