Tractor Talk Discussion Forum
ot/mercury boat motor
D17 man
05-20-2007 16:43:14
hi, i just bought a boat with a mercury 1000 series motor (100 horsepower). i was wonder what ratio to mix the fuel at. i figureed it would be 40:1 but my friend tells me he thinks they run richer more like 20:1. if u could help me figur it out i'd appriciate it
MarkB_MI
05-20-2007 19:22:33
 Re: ot/mercury boat motor in reply to D17 man, 05-20-2007 16:43:14
That must be an old Kiekhaefer Merc. All the ones I've seen ran 50:1. Not to mention that the oil available today for two-cycle outboards is far better than what was available back in the '60s.
Just to double-check myself, I googled on "kiekhaefer" and found the web site below. From the site oldmercs.com:
"The currently preferred fuel is the mid grade (89 octane). All post World War II non-racing Mercs (except KB-4's) can operate safely on a 50 to 1 fuel/oil mixture using modern TCW 3 oil. Racing models and the KB-4's should not be run leaner than 25 to 1."
D.B.in Mi.
05-20-2007 18:23:23
I have a 1976 115 hours on my boat and it runs on the 50-1 mix. I am pretty sure that is what you need to run in yours.
D.B. in Mi.
05-20-2007 18:24:52
 Re: ot/mercury boat motor in reply to D.B.in Mi., 05-20-2007 18:23:23
That is 115 horse motor not hours.
mjbrown
05-20-2007 17:14:41
We've used mercs for years at work. All the two strokes in the last twenty years we've had them were 50:1. The older ones specified a richer mixture but that was based on the two stroke oils of the era the engine was made not on how it was built. I think you can use the 50:1 mix useing the oils made today. Buy the good stuff. Johnson outboards used a 100;1 mix with good results except where engines sat unused for extended periods which would allow internal rusting. So the practice was to use a very rich mix just before layup for the winter.
dave guest
05-20-2007 17:08:49
 Re: ot/johnson 30horse bom badier boat motor in reply to D17 man, 05-20-2007 16:43:14
Neighbor has this. Said he changed plugs and gas line and bulb. Five years old. Won't idle down, spits and pops. Seems to run lean, if you block throttle body it runs better. Fuel injected. We tried 2 sets of plugs. Boat dealer is backed up for 1 month. Silver bass are running. Any info appreciated. Runs fair at higher speeds.
Leland Cole
05-22-2007 12:37:50
 Re: ot/johnson 30horse bom badier boat motor in reply to dave guest, 05-20-2007 17:08:49
try running a couple of cans of seafoam thru gas this is a double dose but it will clean the fuel system out .
mjbrown
05-20-2007 17:24:45
Two stroke or four? The new four strokers are very touchy because they are set at the factory so lean they barely run to be EPA compliant and they can not be adjusted. They don't like ethanol in their fuel or the slightest bit of water or sediment and their filters are rudimentary at best and hard to change. I have added RayCore filters to all our boats and have improved the reliability of our engines signifigantly. You might give it a dose of Sea Foam. I've not used it, but people here have said good things about it.
dave guest
05-20-2007 17:08:41
TomH in PA
05-20-2007 17:07:59
Call a dealer, but they'll probably tell you what they told me - mix ratio is a function of the oil, not the engine. 50-1 oil works in any 2-cycle engine.
Rod in Smiths Falls, ON,
05-20-2007 18:25:00
 Re: ot/mercury boat motor in reply to TomH in PA, 05-20-2007 17:07:59
50:1 didn't work in my McCullough 85 cc chain saw. It calls for 28:1 and when my nephew put the Husqvarna's gas into it, it cost us a new power head.
bo
05-20-2007 16:58:54
some of the earlier ones ran 24-1, later went 50-1..... need the year. Chances are pretty good that it was 50-1.
Curt from MN
05-20-2007 16:55:24
Try MarineEngine.com. Lots of info on your motor there.
