Tractor Talk Discussion Forum
mixing 2-4,D
Dave from MN
05-22-2007 03:54:41
For spot spraying, what is a good mix for spraying to clean up the yard and my grassy areas around the farm. Sprayers are 2 gallon hand sprayer and a 9 gallon ATV sprayer.
Jerry/MT
05-22-2007 10:24:05
 Re: mixing 2-4,D in reply to Dave from MN, 05-22-2007 03:54:41
It depends on what you are trying to kill. If it's just broadleaf weeds, 2,4,-D is cheap and safe if used per the label instructions. If it's woody plants or some of the more invasive noxious weeds, you need something else, like Weedmaster, Crossbow, etc or their generic equivalents.
Dave from MN
05-22-2007 08:53:33
Thanks for the help guys. Yes I am trying to reduce weeeds in my grass. I'll have to wait till the wind is down to spray I guess. Only 10 more acres of beans to gho and my freinds crops are all planted, now for the hay, if it ever rains.
buickanddeere
05-22-2007 07:47:29
Wear gloves and don't get the stuff on your skin. Breathing the mist/fumes in isn't going to make you healthier either. Neighbour is dying of liver cancer and best medical evidence suggests it was likely caused by chemicals around the farm. Studies on Firemen who have worked in emergency situations around similar organic chemicals also shows a very high incidence of liver problems. Your liver wasn't built to breakdown and filter out 2-4-D, lindane etc.
ldj
05-22-2007 09:48:07
 Re: mixing 2-4,D in reply to buickanddeere, 05-22-2007 07:47:29
According to the ld50 factor, 24D is less toxic than caffeine and slightly more toxic than aspirin. My Doctor has me taking aspirin everyday and I drink caffeine daily.
buickanddeere
05-22-2007 15:33:38
 Re: mixing 2-4,D in reply to ldj, 05-22-2007 09:48:07
Is there any reason to get the stuff into your system if you don't have to? I suppose some people may let a little of any chemical on themselves to prove how tough,strong & imortal they are.
KYfarm
05-22-2007 04:30:41
3 oz of 2,4-D per GAL of water, works like a charm
CWL
05-22-2007 04:25:55
2-4,D will only work on broadleaf plants. Will not kill grassy areas.
Allan In NE
05-22-2007 04:42:02
 Re: mixing 2-4,D in reply to CWL, 05-22-2007 04:25:55
Think he is trying to knock the weeds out of his grass, isn't he? That's the way I read it anyways.
Allan
CWL
05-22-2007 05:27:52
 Re: mixing 2-4,D in reply to Allan In NE, 05-22-2007 04:42:02
You might be right.
mjbrown
05-22-2007 04:15:22
I think what ever it says on the container is a good place to start . If it doesn't work as well as you want maybe add a bit more. Burdock seems to need a pretty stiff dose to kill it.
Glen in TX
05-22-2007 09:56:36
 Re: mixing 2-4,D in reply to mjbrown, 05-22-2007 04:15:22
If you mean thistles by burdock best thing to kill them is a stick with rag dauber and just put a bit of old stale gas on them and they will wilt over dying before end of day. It's amazing how that will knock them over fast but chemicals won't. Just don't light it!
