Tractor Talk Discussion Forum
Long 2610 3 pt hitch
Leland jones
05-23-2007 13:20:22
I just purchased a 1995 Long 2610 tractor. It did not come with a 3pt hitch set up. I have been looking all around to purchase the entire cat 2 3 pt hitch. Does anyone know where I might look. Also if anyone has any general comments regarding this model of tractor good or bad it would be appreciated
KEH
05-23-2007 16:06:09
 Re: Long 2610 3 pt hitch in reply to Leland jones, 05-23-2007 13:20:22
The 2610 differs from the older 610 by having a spacer put next to the transmission to give a longer wheel base and more legroom for the operator. As far as I know, the 3ph stuff is the same as on the 610s, also the Oliver 1365 and the White 2-60. The 610 and probably the 510 have a system where to get both Cat I and II the 3ph arms are reversed. I've never seen a 2610 with out 3ph and suspect someone removed some parts. Does the tractor have the rockshaft, draft control, and top link hook up? If all that is missing, you need a parts tractor. Oh yes, some AC tractors like the 5040 and 5050, I think had the same 3ph. Maybe you could Google tractor salvage yards for one close to you. Good luck.
KEH
