Tractor Talk Discussion Forum
Buying a diesel truck
Lincoln
05-23-2007 16:49:16
First off I am not trying to start a color war. That being said I am in the market for a diesel ton truck. I'm undecided on dually or single rear so chime in on that if you have opinions. Looking for something between a 2001 and 2005. I have heard good things about 7.3 Fords, but bad things about the 6.0, especially 03s and 04s. My friend has an 06 duramax, and man does it pull and I like the allison transmission. Not sold on a diesel V-8 though. Which leads me to the Dodge Cummins. The 5.9 straight six is tried and true, and will outlast the truck they are in. I've heard the 05 and new 5.9s have more ponies. Would like to here your opinions on power, fuel mileage, longgevity, etc. Thanks
gmd
05-24-2007 16:12:07
 Re: Buying a diesel truck in reply to Lincoln, 05-23-2007 16:49:16
I have an 06 ford 250 with the 6 speed stick. Very nice truck but i wish I had my 91 non turbo 7.3 in it. that thing was bulletproof. The 6.0 just has nothing in the low end. Now, this is expected when i pull the skid loader around. I think its 7500 lbs plus buckets forks other goodies the trailer and a truckbed loaded with old skool steel ladder racks and too many tools. I think on the quarry scale it showed 980 lbs of stuff in there that i cant live without. Towing the kubota tractor and the IH484 tractor is a nice experience though. The kubota you dont even know its there. Not towing anything it is a fast truck. I baby that thing pretty bad, but when i want it, its there.My dad had a 99 dodge. that motor was awesome but like someone else said the fronts were terrible. he couldnt afford to keep brakes on it. I imagine they fixed that by now.
I think i read that most new duallys are rated to tow 24000 lbs. Now that i cannot believe. Pulling maybe. Stopping? that must be dicey, especially for an emergency stop. If anyone does pull that much I'd like to hear how it handles. Maybe i'm underrating those trucks.
My 2 cents.
Mike M
05-24-2007 05:27:35
More and more for about the same money you can move up to a more heavy duty truck made by Navistar,Freightliner,Peterbuilt etc. they are all makeing lo profile versions of medium duty trucks that will last and have better braking systems.
MeAnthony
05-23-2007 20:57:09
I don't have one myself, but my boss had two 1-ton Dodges, one single wheel and one dually. Pulled a 5th wheel camper from lower Michigan to Florida with each truck. He said the stability in windy conditions was much better with the dually.
Steven@AZ
05-23-2007 20:23:58
Go with the best of both worlds. fordcummins.com
Brother has a 98 Cummins with 165k on it. Usually around 20 to 24mpg empty running 70 mph, will do better if you keep it under 60. Pulling a short haul (about 2 miles each way) moving hay home w/25 foot gooseneck at around 18k lbs, letting it idle with AC on while loading and unloading we got 16 mpg. Long hauls depend on what speed you want to drive, anywhere from 15 to 18 loaded.
His 06 Cummins makes anywhere from 16mpg to 20mpg empty. Depends on how fast you want to get there. Don't have a real good idea of loaded yet, but made 14mpg going 70mph with a load of cattle (around 16k lbs).
Ron in OH
05-23-2007 19:28:11
I have two Duramax units - an 05 GMC 2500 and a 06 Chev 3500. I recently sold a Dodge 2500 diesel with 238,000 on it with no problems. This truck got great mileage - 26 + empty cruising the Interstate. Average 20 pulling a gosseneck round trip one way loaded and back empty. The problem with the Dodge is the tranny. I was lucky I rebuilt the automatic at 150,000 and never touched it again. The GM's I now have are performing very well with the Allison. The 05 has the five speed and the 06 is a six speed with a manual lock in which is nice when pulling loads. Both these trucks do very well and they have the power train to move along. The 05 is equipped with a computer read-out on mileage. To get the best mileage keep the rpm's at 1500 and you will do pretty good. If I'm on the Interstate and cruising at 70 (empty) this truck will hang around 16 - 17, if I back off to 55 it'll get 22 - 23. I can pay myself to drive slower. When loaded I see the same differences. I have checked this with my calculator and the computer is pretty close. The 06 with the six speed will run about 300 rpm less at same speeds as the 05.
The one ton is much better to tow with but the ride in the 2500 empty is better. I have towed heavy loads with the 2500. The 2500 truck and trailer combo with a New Holland 190 skid laoder and attachments hit the scales at around 19,800. Since I now have the 3500 06 it does a much better job at trailering. Good luck on your purchase.
jimtnv
05-23-2007 18:37:06
put a 5.9 in a ford and you've got a tough truck.
I only buy used. I don't plan on getting a new-fangled pickup with gps or dual tv's or 40-way power seats.
jdemaris
05-23-2007 18:28:44
There is no doubt that a "ladder-frame" straight block, such as the Cummins in-line 6 design, is a inherently stronger design that a typical V-8. You cannot count Detroit or Cat V-8s because they are NOT lightweight automotive diesels - they are heavily reinforced. That all being said, all that counts is that the engines will last as long as the trucks. Ford 6.9s/7.3s light-duty diesels, and the Cummins 5.9 a medium duty. Engine life is projected in HD engineering with a "B" rating. Cummins 5.9 has a B10 rating of 250,000 miles. That means only 10% do NOT make it that far. 5.9 also has a B50 rating of 350,000 miles - i.e. 50 % make it, 50 % do not - without major repairs. Ford IH 7.3 has exactly the same B50 rating, but is not considered "medium-duty" because it does not have replaceble sleeves. It's bigger brother, the DT466 does have sleeves and has a B50 rating of 375,000 miles. The new Ford IH 6.4 also has a B50 rating of 375,000 miles. The GM 6.2s and 6.5s never got B ratings, I assume because they were never intended for heavy use. But . . . the Isuzu straight-six-cylinder GM uses in bigger trucks has a B10 rating of 410,000 miles and puts out 810 lb. ft. of torque - that's pretty impressive. The GM Isuzu Duramax V-8 has a B10 rating of 220,000 miles. In regard to cubic inches versus weight, a GM 6.2 or 6.5 weighs 650 lbs. A Ford IH 7.3 weighs 860 lbs. A 6.6 Duramax weighs 836 lbs. 5.9 Cummins weights 1,036 lbs. Obviously, the 5.9 has the most weight per cubic inch, whereas the GM 6.2/6.5 is the lightest. In regard to fuel mileage, I can tell you my own experiences. From what I've driven, and of other trucks I know of, the Dodge Cummins has been the best with fuel mileage - often 19-21 MPG with a 4WD truck on the highway. I've got three neigbors with Duramaxs - Allison trans - and the best report has been 18 MPG. My one neighbor has a rusty 1993 Dodge Cummins that consistently gets 19 MPG highway. His 2005 Durmax with Allison has never done better that 14 MPG. He loves the Durmax for pulling power, but curses it for fuel mileage. I've got a 85 Ford F250 4WD ex-cab, 4.10 gears, C-6 trans and 6.9 diesel and it has never done better than 14 MPG on a highway cruise. Also have a 94 F250 ex-cab 4WD with 4.10 gears and overdrive-auto with 7.3 turbo, and it can get a best highway mileage of 15.5 MPG. Also have MANY 6.2 diesel trucks - the best has gotten 25 MPG but is useless for heavy towing. Farmer next to me has a Dodge Cummins 4WD high-output 5.9 diesel - one year old. He gets 18 MPG highway. I'm sure you'll get other reports - just take everything with a "grain of salt." When I bought my first diesel Suburban - used - the owner told me it got 30 MPG. Found out it got a best of 19 MPG. When I bought my first Ford F250 with 6.9 diesel - the owner told me it got "around" 30 MPG - found out it gets a best of 14 MPG - and I'm not a hard driver.
Andy in IL
05-23-2007 18:12:59
I've owned a 1999 dodge cummins 3/4 ton and traded for a 2005 ford 6.0 f-350. for what I say both are good trucks I don't have any trouble out of the 6.0 (very lucky) the truck has been to the shop twice only for truck related, not engine. If you are just pulling a camper either one would be good, now if you are going to get down to it in pulling hard loads. Can't beat the low end torque of the in line 6 cummins. The v-8 torque in the the higher rpm which you have to get there first. the dually helps alot on the swaying since I pull a 30 ft gooseneck trailer. I hope this helps and let us know what you decide! Good luck
dds-inc
05-23-2007 18:07:33
7.3L Powerstroke is the best engine ford ever put in a truck. FORGET 6.0L "weakerstrokes". The powerstroke 7.3L turbo usually runs 17 mpg with 3.73 rear ends, and has a lot of torque.
Chevrolet duramaxes are basically ISUZU engines. Weak area is the aluminum heads. However, they are a nice smooth running engine. They have a lot of power. They run 18-19 mpg with 3.73 rear ends
Cummins 5.9L 24-valve turbo's found in the 98 through 03 dodges are the great old engines. If you look for one, make sure you get the high output with 6 speed manual, as the automatics usually tear out in the weaker low-output 5.9L's. The dodge trucks of that era have major problems with the front ends falling out from under them. The new style dodges look UGLY but have AAM axles which are heavier duty axles. They run about 20 mpg on a GOOD day with the high speed rear ends.
I don't like automatic. Even if someone's running their mouth about how easy it is to use an automatic, I still love the control and rigidity of a stick.
BY THE WAY...NO SUCH THING AS A FUEL EFFICIENT DIESEL.
dhermesc
05-24-2007 05:09:18
 Re: Buying a diesel truck in reply to dds-inc, 05-23-2007 18:07:33
"7.3L Powerstroke is the best engine ford ever put in a truck. FORGET 6.0L "weakerstrokes". The powerstroke 7.3L turbo usually runs 17 mpg with 3.73 rear ends, and has a lot of torque."
Apparently you've never driven one. We have 3 6.0s in the 2006-2007 range - the 7.3s don't even compare in power or mileage.
dds-inc
05-24-2007 11:19:17
 Re: Buying a diesel truck in reply to dhermesc, 05-24-2007 05:09:18
call me when your little tiny engines eat themselves out.
Brian 1 from Iowa
05-23-2007 18:05:24
I bought a new 2006 Dodge with the 5.9 Cummins about 3 months ago. It is getting better miles/gallon as it gets broke in. Now at 9000 miles I am averaging around 18.5- 19.2 depending on exactly how much town driving I do.
Olivergreen
05-23-2007 17:34:05
Hey Guys Nothen wrong with v8 diesels. Concept been here for years. Detroit 8 71 cat 32o8 just ta point out a couple. Now I like cummings & I like inline 6 cyls. Now there is the old saying,there is no replacement for displacement. I have had great luck with my old 6.9. Even better luck with my 7.3. Have hit 25mpg a couple times empty. Have also done 12mpg pulling 16ft car trailer with 4500- 5500 lbs on it. Never felt short of power even at 70 mph.
phillip d
05-23-2007 17:10:11
i'm not fortunate enough to own a diesel utility truck,but there have been alot of dodges around here in the last 20 years and just about everyone loves the cummings.they claim they get 25 miles to the gallon,which sounds decent to me.as far as single or dually goes,do you need a dually?i know of a person who makes a point to only buy single wheel trucks to put wheels under his fish market buisness.here,if you have a box on a dually,you have to report to the scale houses,means he is usually overweight,he just rolls on by with his single wheel truck,while the dot's think he just has a 3/4 ton.leagle?'nother question,saving him money?ooooo o yeaaaaah!
oj
05-23-2007 17:02:57
What ever colour you end up with, if you intend doing any amount of towing, I"d opt for a dually ever time, they"re far more stable with a load on. As for what colour you want, the Cummins is a damn good engine, not that I"m knocking the others, Isuzu make some great engine too (duramax is an Isuzu design) but i too am not sold on diesel V8"s (although i have a Mercedes V6 in a combine). The newer diesels are common rail, which made good power and low emissions, but should they go wrong they get expensive to fix.But hey, you pays your money and takes your choice. Hope that helps. oj
Rexalot
05-23-2007 20:55:43
 Re: Buying a diesel truck in reply to oj, 05-23-2007 17:02:57
I always had Ford trucks until my current one. It is a gas 1/2 ton Dodge truck. I really like the Fords, but I think my next truck purchase will be a Dodge 3/4 ton 4x4 with the Cummins and a 5spd.
To bad that Allison trans wasn't behind the Cummins... and available in the Ford truck. Now that'd be what I really want.
Unless your towing all the time and heavy loads there is no reason to have the dually. It just becomes two more tires you will have to replace.
It's your dollars, I would probably shop for the best truck for the money. (Thats how I ended up with my current one.)
