Tractor Talk Discussion Forum
ford 5000 diesel stalling when going uphill
George E.Dietz
05-23-2007 17:57:30
when going uphill in high gear and full throttle the engine dies. It take either to start again still going uphill.Runs fine on level.Could itbe the fuel pump?
RodInNS
05-24-2007 20:16:14
 Re: ford 5000 diesel stalling when going uphill in reply to George E.Dietz Jr, 05-23-2007 17:57:30
I would suspect some trash floating around in the tank that momentairly blocks the tank outlet. Mabey leaves or something of that nature.
Remove the shutoff from the tank and clean the tank and screen on the shutoff.
Rod
Scott PA
05-24-2007 17:36:25
Did you change oil in the injection pump whenever you changed in the engine? If not the governor sticks. Did you change the fuel filter? Is there good fuel flow from the tank to the filter, do not blow back through the line unless the fuel tank fill cap is off and the engine is cold and no heat source around, this should be done by a person who knows what they are doing and be carefull.
George E.Dietz Jr
05-24-2007 18:19:23
 Re: ford 5000 diesel stalling when going uphill in reply to Scott PA, 05-24-2007 17:36:25
Thanks I will try that
Nebraska Cowman
05-24-2007 04:38:43
Good grief, how steep is that hill? have you tried using a lower gear? How much fuel is in the tank?
George E.Dietz Jr
05-24-2007 18:21:14
 Re: ford 5000 diesel stalling when going uphill in reply to Nebraska Cowman, 05-24-2007 04:38:43
The hills are the way to another farm over paved roads. It was pulling the hills good until it just stalled.
