Tractor Talk Discussion Forum
Fertilizer needed
Shark
05-24-2007 07:14:44
First.i want to say thank you to all the military personal that have served,or our serving our great U.S.A... I have 4 acres of hay i planted last year,cover crop oats.This year it sure don't look good,thick but not very tall.I'am guessing i should of put fertilizer on it before growing season,after first cutting what number fert should i use? I know soil test should be done,for 4 acres when would a test be done.
mjbrown
05-24-2007 08:13:24
 Re: Fertilizer needed in reply to Shark, 05-24-2007 07:14:44
Ideally soil test before you plant. Since that is not an option now soil test now or soon. You will be shooting blind with out some numbers to tell you what is needed including ph adjustments (lime). All of that assumes it is well enough drained to grow what you want. If it's not nothing you add to the soil will matter. Grass hay responds to nitrogen. Alfalfa needs P&K generally refered to a O goods as in 0-10-50.
