Tractor Talk Discussion Forum
painting panels that have been oil soaked
n8terry
05-25-2007 17:37:35
Hi, I am painting a tractor that has had oil soaked into the metal, mostly hydraulic oil if it makes a difference.
Whats a good way to prepare the metal before painting with final coat?
ben brown
05-26-2007 08:00:30
 Re: painting panels that have been oil soaked in reply to n8terry, 05-25-2007 17:37:35
used ever thing in this world one time or thr other no OVEN CLEANER
flying belgian
05-25-2007 20:06:12
There is a product called metal-prep available at paint stores. It works great.
Walt Davies
05-25-2007 18:37:22
Use Brak-Clean that is what it made for to remove all oils.
Walt
laird006
05-25-2007 18:24:48
wash it down with a good degreaser, then wipe with laquer thinner on rags, sand the parts well, then wipe again.
dds-inc
05-25-2007 18:01:36
I don't think oil really "soaks" into the metal, but if there is any oil on my tractor before painting, I usually use laquer thinner on clean rags and give it a good rubdown.
in-too-deep
05-25-2007 18:07:06
 Re: painting panels that have been oil soaked in reply to dds-inc, 05-25-2007 18:01:36
I'll second that, and don't be bashful with the thinner. It'll evaporate before you can blink.
BarryfromIA
05-25-2007 18:55:33
 Re: painting panels that have been oil soaked in reply to in-too-deep, 05-25-2007 18:07:06
Brake cleaner works great on small parts. It will flush the dirt from sanding off. Give the part 15 minutes or more to dry after spraying.
B-maniac
05-25-2007 19:41:57
 Re: painting panels that have been oil soaked in reply to BarryfromIA, 05-25-2007 18:55:33
I would use brake-clean on any rough or cast parts and thinner on smooth or sheet metal parts. If the sheet metal is pitted , use brake clean on those areas too.
rustyj14
05-28-2007 14:52:36
 Re: painting panels that have been oil soaked in reply to B-maniac, 05-25-2007 19:41:57
Auto paint stores sell a product for cleaning the job just before painting! Removes oil, finger prints, dust or anything that might contaminate the paint. One trade name was Pre-kleano.Laquer thinner dries too fast, enamel reducer is in the family of the product mentioned above. Mineral spirits is also useful as a final wash prior to painting! Gasoline is an oil based product, which will contaminate any surface you wipe with it, prior to painting!
