Tractor Talk Discussion Forum
Re: Finnshed 1st cutting today-Fox chopper photos
Don-Wi
05-26-2007 00:24:21
Looks like you got'er swung all the way open- We only do that for changin the heads! When using the hay head, I may swing it open 1 hole, but ussually that's even optional, as long as the tractor clears the windrow. For corn I either run it 1 or 2 holes out. Ussually 1 hole for the 1st round so I don't run as much down with the tractor, then on the 2nd hole for everything else. Nice shots though!! Here's a couple of mine: third party image third party image third party image
Donovan from Wisconsin
barnrat
05-26-2007 06:00:31
 Re: Finnshed 1st cutting today-Fox chopper photos in reply to Don-Wi, 05-26-2007 00:24:21
I got to run it swung all the way open for several reasons. One mostly when I mow I lay the hay down as wide as the pickup, 6.5 ft, to help it dry faster. Two on some of my steeper fields the chopper will tend to wanna slide back behind the tractor. Three it's easier to get it to go into the last hole. Probably when I set it up to chop or snap corn I will run it as narrow as possible to get as straight a line of pull as possible.
