Tractor Talk Discussion Forum
986 clutch dump valve
andy anderson
05-28-2007 14:38:36
I am having trouble with the clutch dump valve sticking in the out position. The tractor has set outside in western WA over winter. It has a cab and aux fuel tank. There does not appear to be any corrison on/around the outer end of spool valve. The spool will snap back in if moved a little. I have adjusted the clutch, booster, etc by the manual. Any ideas? Hard to take off MCV with aux tank in way.
