Tractor Talk Discussion Forum
engine trouble
kyle in ny
05-29-2007 09:35:53
I finally got my new starter in so I can start the tractor now. The engine runs well for like 15 seconds then backfires like crazy. When I disconnect the #2 cylinder the backfiring stops. I should also add that when I pull that plug there is wet oil on it. I was thinking that it has either bad rings or a hole in the piston. When I run the engine with the plug out, oil doesn"t splash out like I have seen with an instance with a hole in a piston. Any ideas?? Thanks
dds-inc
05-29-2007 19:22:18
 Re: engine trouble in reply to kyle in ny, 05-29-2007 09:35:53
this is a general symptom of an intake valve not seating due to excess carbon build-up. Take tractor out in the field and pull a plow. might work itself carbon-free
flying belgian
05-29-2007 18:05:38
I agree with W.D.
mjbrown
05-29-2007 12:36:33
A compression test will answer your questions about hole in piston, worn rings or intake valve hanging up.
ldj
05-29-2007 10:50:32
Put the spark plugs in opposite cylinders and see if the problem reverses. in other words disconnect # 1 and backfiring stops. There is a good chance that # 2 spark plug is breaking down.
L.D.
Walt Davies
05-29-2007 10:08:42
Intake valve hanging up.
Walt
