Tractor Talk Discussion Forum
OT I didn't know this
tmay
05-30-2007 10:33:06
Back in the winter my son wrecked his 1500 Dodge truck. Messed upthe R fender and L door. Soooo I finally found them. I bought them and guess what? They fit a 3500 dodge of the same year. Now I knew they were for a 3500 but did not realize that they would not fit a 1500. Just wanted you all to know that in case this happens to you. I thought the 1500, 2500 and 3500 were all the sme body style. Oh well live and learn. By the way anyone need them LOL.Thanks for listening
dds-inc
05-30-2007 17:01:19
 Re: OT I didn't know this in reply to tmay, 05-30-2007 10:33:06
sir,
i wouldn't have even known. all my Ford F-series pickups through 1993 and 1997 fit perfectly together with different year body parts, even the doors and tailgates.
I do declare that you might try E-bay to list the things you have bought.
Steven@AZ
05-30-2007 15:37:54
Just put a 97 1500 cab on a 98 2500 diesel pickup... dropped right on. Had to cut a hole for the shift lever and weld in the different brackets for the seats.
Bus Driver
05-30-2007 13:59:02
On some trucks of some years, the 1/2 ton (1500) will be unique and the 2500/3500 bodies will be identical.
tmay
05-30-2007 13:51:23
Yes the door and fender came off the same year truck 1995. The only difference is the truck is a 1500 and the door and fender came off a 3500. The fender is about 1/2" longer than what is on the truck and the door will go on but it will not shut at the top. The way it is made leaves a gap.
Luke S
05-30-2007 13:43:18
You must be refering to an 02'. In 02' the 1500 series was redesigned to the current body style but the 2500 and 3500's did not get that design until the 03' model year.
adam smith
05-30-2007 13:09:40
yep thats right, the 1500 and 2500 are the same but the 3500's are different
colekicker
05-30-2007 12:14:40
Interesting. Didn't know that either. dieseltruckresource.com is a good place to list the stuff if you need to get rid of it now.
Jim K
05-30-2007 13:00:57
 Re: OT I didn't know this in reply to colekicker, 05-30-2007 12:14:40
That aint right.
Were they both the same year truck?
