Tractor Talk Discussion Forum
Belarus Hydraulic fluid
hayrookie
05-31-2007 03:33:27
The manual for my Belarus 400A tractor says to use SAE 30 for the hydraulics. What is the difference between SAE 30 and standard Tractor hydraulic fluid. Which one is thicker?
Thanks
Trkr
05-31-2007 09:13:44
 Re: Belarus Hydraulic fluid in reply to hayrookie, 05-31-2007 03:33:27
Belarus always told you to use a heavier oil than hyd. oil because of there poor clearences in their valves and other hyd. components.
nhboyd
05-31-2007 05:41:11
most hyd.fluids are 20 wt. I have used hyd fluid in winter in Belarus to make loader work better.
Jon Hagen
05-31-2007 09:04:57
 Re: Belarus Hydraulic fluid in reply to nhboyd, 05-31-2007 05:41:11
If you have implements that are used on more tractors than just your Belarus,consider that oil left in the implement hydraulics will contaminate both tractors hydraulic systems. This would be a good reason to use the same fluid in all your tractors if the fluid meets the hyd fluid spec for all tractors.
We ran into this a few years ago when Cat challengers could be ordered from the factory with bio degradable vegetable oil based hyd fluid that no one else used.
